00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.event; 00032 00033 00048 public class ProActiveEvent extends java.util.EventObject 00049 implements java.io.Serializable { 00050 public static final int GENERIC_TYPE = -1; 00051 00053 protected int type; 00054 00056 protected long timeStamp; 00057 00063 public ProActiveEvent(Object obj, int type) { 00064 super(obj); 00065 this.timeStamp = System.currentTimeMillis(); 00066 this.type = type; 00067 } 00068 00073 public long getTimeStamp() { 00074 return timeStamp; 00075 } 00076 00081 public int getType() { 00082 return type; 00083 } 00084 00085 public String toString() { 00086 return "ProActiveEvent@" + timeStamp + " type=" + type; 00087 } 00088 }
1.5.1
