00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.config;
00032
00033 import java.util.ArrayList;
00034 import java.util.HashMap;
00035 import java.util.Iterator;
00036 import java.util.List;
00037
00038 import org.apache.log4j.ConsoleAppender;
00039 import org.apache.log4j.Level;
00040 import org.apache.log4j.Logger;
00041 import org.apache.log4j.PatternLayout;
00042 import org.objectweb.proactive.core.UniqueID;
00043 import org.objectweb.proactive.core.config.xml.MasterFileHandler;
00044 import org.objectweb.proactive.core.util.log.Loggers;
00045 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00046
00047
00054 public class ProActiveConfiguration {
00055 protected HashMap<String, String> loadedProperties;
00056 protected HashMap addedProperties;
00057 protected static ProActiveConfiguration singleton;
00058 protected static boolean isLoaded = false;
00059 protected static boolean defaultConfigAlreadyLoaded = false;
00060 protected static List<String> jvmDefinedProperties = new ArrayList<String>();
00061
00062 private ProActiveConfiguration() {
00063 this.loadedProperties = new HashMap<String, String>();
00064 this.addedProperties = new HashMap();
00065 }
00066
00067 protected static synchronized void createConfiguration() {
00068 if (ProActiveConfiguration.singleton == null) {
00069 ProActiveConfiguration.singleton = new ProActiveConfiguration();
00070 }
00071 }
00072
00081 public static void load() {
00082 if (!isLoaded) {
00083 loadDefaultConfig();
00084 isLoaded = true;
00085 }
00086 }
00087
00088 private static void loadDefaultConfig() {
00089 String filename = null;
00090 filename = ProActiveConfiguration.class.getResource(
00091 "ProActiveConfiguration.xml").toString();
00092 MasterFileHandler.createMasterFileHandler(filename,
00093 ProActiveConfiguration.getConfiguration());
00094 ProActiveConfiguration.getConfiguration().loadProperties();
00095 if (System.getProperty("log4j.configuration") == null) {
00096 loadDefaultLogger();
00097 }
00098 defaultConfigAlreadyLoaded = true;
00099 }
00100
00105 public static void load(String filename) {
00106 if (!isLoaded) {
00107 if (!defaultConfigAlreadyLoaded) {
00108 loadDefaultConfig();
00109 }
00110 MasterFileHandler.createMasterFileHandler(filename,
00111 ProActiveConfiguration.getConfiguration());
00112 ProActiveConfiguration.getConfiguration().loadProperties();
00113 isLoaded = true;
00114 }
00115 }
00116
00117 public synchronized static ProActiveConfiguration getConfiguration() {
00118 if (ProActiveConfiguration.singleton == null) {
00119 ProActiveConfiguration.createConfiguration();
00120 }
00121 return singleton;
00122 }
00123
00129 public void propertyFound(String name, String value) {
00130 this.loadedProperties.put(name, value);
00131 }
00132
00136 public void loadProperties() {
00137 Iterator<String> it = loadedProperties.keySet().iterator();
00138 String name = null;
00139 String value = null;
00140 while (it.hasNext()) {
00141 name = it.next();
00142 value = this.loadedProperties.get(name);
00143 if (!defaultConfigAlreadyLoaded) {
00144
00145 if (System.getProperty(name) == null) {
00146 System.setProperty(name, value);
00147 } else {
00148 jvmDefinedProperties.add(name);
00149 }
00150 } else {
00151 if (!jvmDefinedProperties.contains(name)) {
00152
00153 System.setProperty(name, value);
00154 }
00155 }
00156 }
00157 }
00158
00159
00160
00161
00162
00163
00164
00165
00166
00167
00168
00169
00170
00171
00172
00173
00174
00175
00176
00177
00178
00179
00180
00181
00182
00183
00184
00185 public static String getLocationServerClass() {
00186 return System.getProperty("proactive.locationserver");
00187 }
00188
00189 public static String getLocationServerRmi() {
00190 return System.getProperties().getProperty("proactive.locationserver.rmi");
00191 }
00192
00193 public static String getACState() {
00194 return System.getProperty("proactive.future.ac");
00195 }
00196
00197 public static String getSchemaValidationState() {
00198 return System.getProperty("schema.validation");
00199 }
00200
00201
00202 public static String getFTState() {
00203 return System.getProperty("proactive.ft");
00204 }
00205
00206 public static String getCheckpointServer() {
00207 return System.getProperty("proactive.ft.server.checkpoint");
00208 }
00209
00210 public static String getLocationServer() {
00211 return System.getProperty("proactive.ft.server.location");
00212 }
00213
00214 public static String getRecoveryServer() {
00215 return System.getProperty("proactive.ft.server.recovery");
00216 }
00217
00218 public static String getGlobalFTServer() {
00219 return System.getProperty("proactive.ft.server.global");
00220 }
00221
00222 public static String getTTCValue() {
00223 return System.getProperty("proactive.ft.ttc");
00224 }
00225
00226 public static String getAttachedResourceServer() {
00227 return System.getProperty("proactive.ft.server.resource");
00228 }
00229
00230 public static String getFTProtocol() {
00231 return System.getProperty("proactive.ft.protocol");
00232 }
00233
00234 public static boolean osgiServletEnabled() {
00235 return "enabled".equals(System.getProperty("proactive.http.servlet"));
00236 }
00237
00238
00239 private static boolean isForwarder;
00240
00241 static {
00242 String prop = System.getProperty("proactive.hierarchicalRuntime");
00243 isForwarder = ((prop != null) &&
00244 (prop.equals("true") || prop.equals("root")));
00245 }
00246
00247 public static boolean isForwarder() {
00248 return isForwarder;
00249 }
00250
00251 public static String getGroupInformation() {
00252 return System.getProperty("proactive.groupInformation",
00253 UniqueID.getCurrentVMID().toString() + "~-1");
00254 }
00255
00256
00257
00258
00259
00260
00261
00262
00263
00264
00265
00266
00267
00268
00269
00270
00271
00272
00273
00274
00275
00279 private static void loadDefaultLogger() {
00280
00281
00282 Logger logger = ProActiveLogger.getLogger(Loggers.CORE);
00283 logger.setAdditivity(false);
00284 logger.setLevel(Level.INFO);
00285 logger.addAppender(new ConsoleAppender(new PatternLayout()));
00286 }
00287 }
