00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.representative;
00032
00033 import java.io.Serializable;
00034 import java.lang.reflect.Constructor;
00035 import java.lang.reflect.TypeVariable;
00036 import java.util.HashMap;
00037 import java.util.Iterator;
00038 import java.util.Map;
00039
00040 import org.apache.log4j.Logger;
00041 import org.objectweb.fractal.api.Component;
00042 import org.objectweb.fractal.api.Interface;
00043 import org.objectweb.fractal.api.NoSuchInterfaceException;
00044 import org.objectweb.fractal.api.Type;
00045 import org.objectweb.fractal.api.control.BindingController;
00046 import org.objectweb.fractal.api.control.ContentController;
00047 import org.objectweb.fractal.api.type.ComponentType;
00048 import org.objectweb.fractal.api.type.InterfaceType;
00049 import org.objectweb.proactive.core.ProActiveRuntimeException;
00050 import org.objectweb.proactive.core.UniqueID;
00051 import org.objectweb.proactive.core.body.proxy.UniversalBodyProxy;
00052 import org.objectweb.proactive.core.component.ComponentParameters;
00053 import org.objectweb.proactive.core.component.Constants;
00054 import org.objectweb.proactive.core.component.Fractive;
00055 import org.objectweb.proactive.core.component.ProActiveInterface;
00056 import org.objectweb.proactive.core.component.Utils;
00057 import org.objectweb.proactive.core.component.config.ComponentConfigurationHandler;
00058 import org.objectweb.proactive.core.component.controller.AbstractProActiveController;
00059 import org.objectweb.proactive.core.component.controller.ComponentParametersController;
00060 import org.objectweb.proactive.core.component.gen.RepresentativeInterfaceClassGenerator;
00061 import org.objectweb.proactive.core.component.identity.ProActiveComponent;
00062 import org.objectweb.proactive.core.component.identity.ProActiveComponentImpl;
00063 import org.objectweb.proactive.core.component.request.ComponentRequest;
00064 import org.objectweb.proactive.core.component.type.ProActiveInterfaceType;
00065 import org.objectweb.proactive.core.group.ProxyForGroup;
00066 import org.objectweb.proactive.core.mop.MethodCall;
00067 import org.objectweb.proactive.core.mop.Proxy;
00068 import org.objectweb.proactive.core.mop.StubObject;
00069 import org.objectweb.proactive.core.util.log.Loggers;
00070 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00071
00072
00092 public class ProActiveComponentRepresentativeImpl
00093     implements ProActiveComponentRepresentative, Serializable {
00094     private static Logger logger = ProActiveLogger.getLogger(Loggers.COMPONENTS);
00095
00096     private Map fcInterfaceReferences;
00097     private Map nfInterfaceReferences;
00098     private Proxy proxy;
00099
00100     private ComponentType componentType = null;
00101     private StubObject stubOnBaseObject = null;
00102     private String hierarchicalType = null;
00103     private String currentControllerInterface = null;
00104     private boolean useShortcuts;
00105
00106     public ProActiveComponentRepresentativeImpl(ComponentType componentType,
00107         String hierarchicalType, String controllersConfigFileLocation) {
00108         this.componentType = componentType;
00109         useShortcuts = ("true".equals(System.getProperty(
00110                     "proactive.components.use_shortcuts")));
00111         this.hierarchicalType = hierarchicalType;
00112         addControllers(componentType, controllersConfigFileLocation);
00113
00114
00115
00116         addFunctionalInterfaces(componentType);
00117     }
00118
00122     private void addFunctionalInterfaces(ComponentType componentType) {
00123         fcInterfaceReferences = new HashMap(componentType.getFcInterfaceTypes().length);
00124         InterfaceType[] interface_types = componentType.getFcInterfaceTypes();
00125         try {
00126             for (int j = 0; j < interface_types.length; j++) {
00127                 if (!interface_types[j].isFcCollectionItf()) {
00128
00129
00130                 Interface interface_reference = RepresentativeInterfaceClassGenerator.instance()
00131        .generateFunctionalInterface(interface_types[j].getFcItfName(),
00132                         this, (ProActiveInterfaceType)interface_types[j]);
00133
00134
00135                 fcInterfaceReferences.put(interface_reference.getFcItfName(),
00136                     interface_reference);
00137                 }
00138
00139             }
00140         } catch (Exception e) {
00141             e.printStackTrace();
00142             throw new RuntimeException("cannot create interface references : " +
00143                 e.getMessage());
00144         }
00145     }
00146
00147     private void addControllers(ComponentType componentType,
00148         String controllersConfigFileLocation) {
00149         if (controllersConfigFileLocation == null) {
00150             return;
00151         }
00152         ComponentConfigurationHandler componentConfiguration = ProActiveComponentImpl.loadControllerConfiguration(controllersConfigFileLocation);
00153         Map controllersConfiguration = componentConfiguration.getControllers();
00154
00155         addControllers(componentType, controllersConfiguration);
00156     }
00157
00158     private void addControllers(ComponentType componentType,
00159         Map controllersConfiguration) {
00160
00161
00162
00163
00164
00165
00166
00167         nfInterfaceReferences = new HashMap(1 +
00168                 controllersConfiguration.size());
00169
00170         int i = 0;
00171
00172
00173
00174         Iterator iteratorOnControllers = controllersConfiguration.keySet()
00175        .iterator();
00176         Class controllerClass = null;
00177         AbstractProActiveController currentController;
00178         ProActiveInterface currentInterface = null;
00179         Class controllerItf;
00180         while (iteratorOnControllers.hasNext()) {
00181             String controllerItfName = (String) iteratorOnControllers.next();
00182             try {
00183                 controllerItf = Class.forName(controllerItfName);
00184                 controllerClass = Class.forName((String) controllersConfiguration.get(
00185                             controllerItf.getName()));
00186                 Constructor controllerClassConstructor = controllerClass.getConstructor(new Class[] {
00187                             Component.class
00188                         });
00189                 currentController = (AbstractProActiveController) controllerClassConstructor.newInstance(new Object[] {
00190                             this
00191                         });
00192                 currentInterface = RepresentativeInterfaceClassGenerator.instance()
00193        .generateControllerInterface(currentController.getFcItfName(),
00194                         this, (ProActiveInterfaceType) currentController.getFcItfType());
00195                 ((StubObject)currentInterface).setProxy(proxy);
00196             } catch (Exception e) {
00197                 logger.error("could not create controller " +
00198                     controllersConfiguration.get(controllerItfName) + " : " +
00199                     e.getMessage());
00200                 continue;
00201             }
00202
00203             if (BindingController.class.isAssignableFrom(controllerClass)) {
00204                 if ((hierarchicalType.equals(Constants.PRIMITIVE) &&
00205                         (Fractive.getClientInterfaceTypes(componentType).length == 0))) {
00206
00207                     if (logger.isDebugEnabled()) {
00208                         logger.debug(
00209                             "user component class of this component does not have any client interface. It will have no BindingController");
00210                     }
00211                     continue;
00212                 }
00213             }
00214             if (ContentController.class.isAssignableFrom(controllerClass)) {
00215                 if (Constants.PRIMITIVE.equals(hierarchicalType)) {
00216
00217                     continue;
00218                 }
00219             }
00220             if (currentInterface != null) {
00221                 nfInterfaceReferences.put(currentController.getFcItfName(),
00222                     currentInterface);
00223
00224                 i++;
00225             }
00226         }
00227     }
00228
00229     protected Object reifyCall(String className, String methodName,
00230         Class[] parameterTypes, Object[] effectiveParameters, short priority) {
00231         try {
00232             return proxy.reify((MethodCall) MethodCall.getComponentMethodCall(
00233                     Class.forName(className).getDeclaredMethod(methodName,
00234                         parameterTypes), effectiveParameters, null, (String) null, null,
00235                     priority));
00236
00237
00238         } catch (NoSuchMethodException e) {
00239             throw new ProActiveRuntimeException(e.toString());
00240         } catch (ClassNotFoundException e) {
00241             throw new ProActiveRuntimeException(e.toString());
00242         } catch (Throwable e) {
00243             throw new ProActiveRuntimeException(e.toString());
00244         }
00245     }
00246
00247
00248
00249
00250
00251     public Object getFcInterface(String interfaceName)
00252         throws NoSuchInterfaceException {
00253         if (interfaceName.endsWith("-controller") &&
00254                 !("attribute-controller".equals(interfaceName))) {
00255             if (nfInterfaceReferences == null) {
00256
00257                 ComponentParameters params = (ComponentParameters) reifyCall(ComponentParametersController.class.getName(),
00258                         "getComponentParameters", new Class[] {  },
00259                         new Object[] {  }, ComponentRequest.STRICT_FIFO_PRIORITY);
00260                 hierarchicalType = params.getHierarchicalType();
00261                 addControllers(componentType,
00262                     params.getControllerDescription().getControllersSignatures());
00263             }
00264             if (nfInterfaceReferences.containsKey(interfaceName)) {
00265                 return nfInterfaceReferences.get(interfaceName);
00266             } else {
00267                 throw new NoSuchInterfaceException(interfaceName);
00268             }
00269         }
00270
00271         if (fcInterfaceReferences.containsKey(interfaceName)) {
00272                 return fcInterfaceReferences.get(interfaceName);
00273         } else {
00274
00275                 InterfaceType itfType = Utils.getItfType(interfaceName, this);
00276                 if (itfType !=null && itfType.isFcCollectionItf()) {
00277
00278                         try {
00279
00280                                         Interface interface_reference = RepresentativeInterfaceClassGenerator.instance()
00281                                                 .generateFunctionalInterface(interfaceName,
00282        this, (ProActiveInterfaceType)itfType);
00283
00284                                         ((StubObject)interface_reference).setProxy(proxy);
00285
00286                                         fcInterfaceReferences.put(interfaceName,interface_reference);
00287                                         return interface_reference;
00288
00289                                 } catch (SecurityException e) {
00290
00291                                         e.printStackTrace();
00292                                 } catch (Throwable e) {
00293                                         e.printStackTrace();
00294                                 }
00295                 }
00296         }
00297
00298
00299
00300         throw new NoSuchInterfaceException(interfaceName);
00301     }
00302
00303
00304
00305
00306     public Object[] getFcInterfaces() {
00307         Interface[] nfInterfaces = (Interface[]) (nfInterfaceReferences.values()
00308        .toArray(new Interface[nfInterfaceReferences.size()]));
00309         Interface[] fcInterfaces = (Interface[]) (fcInterfaceReferences.values()
00310        .toArray(new Interface[fcInterfaceReferences.size()]));
00311         Interface[] result = new Interface[nfInterfaces.length +
00312             fcInterfaces.length];
00313         System.arraycopy(nfInterfaces, 0, result, 0, nfInterfaces.length);
00314         System.arraycopy(fcInterfaces, 0, result, nfInterfaces.length,
00315             fcInterfaces.length);
00316         return result;
00317     }
00318
00319
00320
00321
00322     public Type getFcType() {
00323         return componentType;
00324     }
00325
00326
00327
00328
00329     public Proxy getProxy() {
00330         return proxy;
00331     }
00332
00333
00334
00335
00336     public void setProxy(Proxy proxy) {
00337
00338         this.proxy = proxy;
00339
00340         Object[] interfaces = getFcInterfaces();
00341         ProActiveInterface[] interface_references = new ProActiveInterface[interfaces.length];
00342         for (int i = 0; i < interfaces.length; i++) {
00343             interface_references[i] = (ProActiveInterface) interfaces[i];
00344         }
00345         for (int i = 0; i < interface_references.length; i++) {
00346             if (useShortcuts) {
00347
00348                 ((StubObject) interface_references[i]).setProxy(new FunctionalInterfaceProxyImpl(
00349                         proxy, interface_references[i].getFcItfName()));
00350             } else {
00351                 try {
00352                     ((StubObject) interface_references[i]).setProxy(proxy);
00353                 } catch (RuntimeException e) {
00354                     logger.error(e.getMessage());
00355                     throw new ProActiveRuntimeException(e);
00356                 }
00357             }
00358         }
00359     }
00360
00365     public boolean equals(Object component) {
00366         Object result = reifyCall(Object.class.getName(), "equals",
00367                 new Class[] { Object.class }, new Object[] { component },
00368                 ComponentRequest.STRICT_FIFO_PRIORITY);
00369         return ((Boolean) result).booleanValue();
00370     }
00371
00372     public int hashCode() {
00373
00374         Object result;
00375                 try {
00376                         result = proxy.reify((MethodCall) MethodCall.getMethodCall(
00377                                  Class.forName(Object.class.getName()).getDeclaredMethod("hashCode",
00378                                      new Class[] {}), new Object[] {}, (Map<TypeVariable, Class>)null));
00379                 return ((Integer) result).intValue();
00380                 } catch (SecurityException e) {
00381                         throw new ProActiveRuntimeException(e.toString());
00382                 } catch (NoSuchMethodException e) {
00383                         throw new ProActiveRuntimeException(e.toString());
00384                 } catch (ClassNotFoundException e) {
00385                         throw new ProActiveRuntimeException(e.toString());
00386                 } catch (Throwable e) {
00387                         throw new ProActiveRuntimeException(e.toString());
00388                 }
00389
00390     }
00391
00392
00396     public UniqueID getID() {
00397         if (!(getProxy() instanceof ProxyForGroup)) {
00398             return ((UniversalBodyProxy) getProxy()).getBodyID();
00399         } else {
00400             return null;
00401         }
00402     }
00403
00404
00405
00406
00407     public Object getReferenceOnBaseObject() {
00408         logger.error(
00409             "getReferenceOnBaseObject() method is not available in component representatives");
00410         return null;
00411     }
00412
00413
00414
00415
00416     public ProActiveComponent getRepresentativeOnThis() {
00417         return this;
00418     }
00419
00420
00421
00422
00423     public StubObject getStubOnBaseObject() {
00424         return stubOnBaseObject;
00425     }
00426
00427
00428
00429
00430     public void setStubOnBaseObject(StubObject stub) {
00431         stubOnBaseObject = stub;
00432     }
00433
00434     private boolean isPrimitive() {
00435         return Constants.PRIMITIVE.equals(hierarchicalType);
00436     }
00437
00438         public void _terminateAO(Proxy proxy) {
00439
00440         }
00441
00442         public void _terminateAOImmediatly(Proxy proxy) {
00443         }
00444
00445 }
