org/objectweb/proactive/core/component/representative/ProActiveComponentRepresentativeFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component.representative;
00032
00033 import org.objectweb.fractal.api.type.ComponentType;
00034 import org.objectweb.proactive.core.body.proxy.BodyProxy;
00035 import org.objectweb.proactive.core.component.ComponentParameters;
00036 import org.objectweb.proactive.core.component.Constants;
00037 import org.objectweb.proactive.core.component.controller.ComponentParametersController;
00038 import org.objectweb.proactive.core.component.request.ComponentRequest;
00039 import org.objectweb.proactive.core.mop.MethodCall;
00040 import org.objectweb.proactive.core.mop.Proxy;
00041
00042
00049 public class ProActiveComponentRepresentativeFactory {
00050     private static ProActiveComponentRepresentativeFactory INSTANCE = null;
00051
00052     private ProActiveComponentRepresentativeFactory() {
00053     }
00054
00059     public static ProActiveComponentRepresentativeFactory instance() {
00060         if (INSTANCE == null) {
00061             return (INSTANCE = new ProActiveComponentRepresentativeFactory());
00062         } else {
00063             return INSTANCE;
00064         }
00065     }
00066
00077     public ProActiveComponentRepresentative createComponentRepresentative(
00078         ComponentType componentType, String hierarchicalType, Proxy proxy,
00079         String controllerConfigFileLocation) {
00080         ProActiveComponentRepresentative representative = new ProActiveComponentRepresentativeImpl(componentType,
00081                 hierarchicalType, controllerConfigFileLocation);
00082         representative.setProxy(proxy);
00083         return representative;
00084     }
00085
00093     public ProActiveComponentRepresentative createComponentRepresentative(
00094         Proxy proxy) throws Throwable {
00095         ((BodyProxy) proxy).getBody().getRemoteAdapter().setImmediateService("getComponentParameters",
00096             new Class[] {  });
00097         ComponentParameters componentParameters = (ComponentParameters) proxy.reify((MethodCall) MethodCall.getComponentMethodCall(
00098                     ComponentParametersController.class.getDeclaredMethod(
00099                         "getComponentParameters", new Class[] {  }),
00100                     new Object[] {  }, null,
00101                     Constants.COMPONENT_PARAMETERS_CONTROLLER, null,
00102                     ComponentRequest.STRICT_FIFO_PRIORITY));
00103         ((BodyProxy) proxy).getBody().getRemoteAdapter().removeImmediateService("getComponentParameters",
00104             new Class[] {  });
00105         return ProActiveComponentRepresentativeFactory.instance()
00106                                                       .createComponentRepresentative(componentParameters.getComponentType(),
00107             componentParameters.getHierarchicalType(), proxy,
00108             componentParameters.getControllerDescription()
00109                                .getControllersConfigFileLocation());
00110     }
00111 }
Generated on Mon Jan 22 15:16:07 2007 for ProActive by  doxygen 1.5.1
