00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.adl.components; 00032 00033 import org.objectweb.fractal.adl.components.ComponentBuilder; 00034 import org.objectweb.fractal.api.Component; 00035 import org.objectweb.fractal.util.Fractal; 00036 00037 00045 public class ProActiveComponentBuilder implements ComponentBuilder { 00046 // -------------------------------------------------------------------------- 00047 // Implementation of the ComponentBuilder interface 00048 // -------------------------------------------------------------------------- 00049 public void addComponent(final Object superComponent, 00050 final Object subComponent, final String name, final Object context) 00051 throws Exception { 00052 Fractal.getContentController((Component) superComponent) 00053 .addFcSubComponent((Component) subComponent); 00054 // as opposed to the standard fractal implementation, we do not set 00055 // the name of the component here because : 00056 // 1. it is already name at instantiation time 00057 // 2. it could be a group of components, and we do not want to give the 00058 // same name to all the elements of the group 00059 // try { 00060 // Fractal.getNameController((Component)subComponent).setFcName(name); 00061 // } catch (NoSuchInterfaceException ignored) { 00062 // } 00063 } 00064 00065 public void startComponent(final Object component, final Object context) 00066 throws Exception { 00067 } 00068 }
1.5.1
