00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.classloader;
00032
00033 import org.apache.log4j.Logger;
00034 import org.objectweb.proactive.core.mop.JavassistByteCodeStubBuilder;
00035 import org.objectweb.proactive.core.mop.MOPClassLoader;
00036 import org.objectweb.proactive.core.mop.Utils;
00037 import org.objectweb.proactive.core.runtime.ProActiveRuntimeImpl;
00038 import org.objectweb.proactive.core.util.ClassDataCache;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00042
00054 public class ProActiveClassLoaderHelper {
00055     private static Logger logger = ProActiveLogger.getLogger(Loggers.CLASSLOADING);
00056     private ClassDataCache classCache;
00057
00058     public ProActiveClassLoaderHelper() {
00059         classCache = ClassDataCache.instance();
00060     }
00061
00068     public synchronized byte[] getClassData(String className) throws ClassNotFoundException {
00069         byte[] class_data = null;
00070
00071
00072         debug("looking for " + className + "  in class data cache");
00073         class_data = classCache.getClassData(className);
00074         if (class_data != null) {
00075             debug("found " + className + " in class data cache");
00076             return class_data;
00077         }
00078
00079
00080         try {
00081             debug("looking for " + className + " in parent runtimes");
00082
00083             class_data = ProActiveRuntimeImpl.getProActiveRuntime()
00084                                              .getClassDataFromParentRuntime(className);
00085             if (class_data != null) {
00086                 debug("found " + className + " in ancestor runtime");
00087                 return class_data;
00088             }
00089         } catch (Exception e) {
00090             e.printStackTrace();
00091
00092         }
00093
00094
00095         if (Utils.isStubClassName(className)) {
00096
00097             logger.info("Generating class : " + className);
00098
00099             String classname = Utils.convertStubClassNameToClassName(className);
00100
00101
00102
00103
00104
00105
00106                 if (MOPClassLoader.BYTE_CODE_MANIPULATOR.equals("javassist")) {
00107                 class_data = JavassistByteCodeStubBuilder.create(classname, null);
00108             } else {
00109
00110                 System.err.println(
00111                     "byteCodeManipulator argument is optionnal. If specified, it can only be set to javassist (ASM is no longer supported).");
00112                 System.err.println(
00113                     "Any other setting will result in the use of javassist, the default bytecode manipulator framework");
00114             }
00115             if (class_data != null) {
00116                 classCache.addClassData(className, class_data);
00117                 return class_data;
00118             }
00119         }
00120
00121         if (class_data != null) {
00122             return class_data;
00123         }
00124
00125
00126         class_data = org.objectweb.proactive.core.component.gen.Utils.getClassData(className);
00127
00128         if (class_data != null) {
00129             classCache.addClassData(className, class_data);
00130             return class_data;
00131         }
00132
00133         throw new ClassNotFoundException(className);
00134     }
00135
00136     private void debug(String message) {
00137         if (logger.isDebugEnabled()) {
00138             logger.debug(ProActiveRuntimeImpl.getProActiveRuntime().getURL() +
00139                 " --> " + message);
00140         }
00141     }
00142 }
