00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.security; 00032 00033 import java.io.Serializable; 00034 import java.util.ArrayList; 00035 00036 import org.objectweb.proactive.ext.security.securityentity.DefaultEntity; 00037 import org.objectweb.proactive.ext.security.securityentity.Entity; 00038 00039 00040 public class PolicyRule implements Serializable { 00041 protected ArrayList<Entity> from; 00042 protected ArrayList<Entity> to; 00043 protected Communication communicationReply; 00044 protected Communication communicationRequest; 00045 protected boolean migration = false; 00046 protected boolean aocreation = false; 00047 00052 public PolicyRule() { 00053 from = new ArrayList<Entity>(); 00054 from.add(new DefaultEntity()); 00055 to = new ArrayList<Entity>(); 00056 to.add(new DefaultEntity()); 00057 communicationReply = new Communication(); 00058 communicationRequest = new Communication(); 00059 } 00060 00064 public void setEntitiesFrom(ArrayList<Entity> object) { 00065 this.from = object; 00066 } 00067 00071 public void setEntitiesTo(ArrayList<Entity> object) { 00072 this.to = object; 00073 } 00074 00078 public void setCommunicationRulesRequest(Communication object) { 00079 communicationRequest = object; 00080 } 00081 00085 public void setCommunicationRulesReply(Communication object) { 00086 communicationReply = object; 00087 } 00088 00089 public String toString() { 00090 String vnFrom; 00091 String vnTo; 00092 vnFrom = vnTo = null; 00093 if (from == null) { 00094 vnFrom = null; 00095 } else { 00096 Entity[] f = new Entity[0]; 00097 Entity[] eF = (Entity[]) from.toArray(f); 00098 for (int i = 0; i < eF.length; i++) 00099 vnFrom = eF[i].getName() + ","; 00100 } 00101 if (to == null) { 00102 vnTo = null; 00103 } else { 00104 Entity[] f = new Entity[0]; 00105 Entity[] eT = (Entity[]) to.toArray(f); 00106 for (int i = 0; i < eT.length; i++) 00107 vnTo = eT[i].getName() + ","; 00108 } 00109 00110 return vnFrom + "-->" + vnTo + "|| Request:" + communicationRequest + 00111 " :: Reply : " + communicationReply + " || Migration :" + migration + 00112 "|| AOCreation:" + aocreation; 00113 } 00114 00118 public void setCommunicationRules(Communication[] arrayLists) { 00119 setCommunicationRulesReply(arrayLists[0]); 00120 setCommunicationRulesRequest(arrayLists[1]); 00121 } 00122 00123 public Communication getCommunicationReply() { 00124 return communicationReply; 00125 } 00126 00127 public Communication getCommunicationRequest() { 00128 return communicationRequest; 00129 } 00130 00131 public ArrayList getEntitiesFrom() { 00132 return from; 00133 } 00134 00135 public ArrayList getEntitiesTo() { 00136 return to; 00137 } 00138 00142 public boolean isAocreation() { 00143 return aocreation; 00144 } 00145 00149 public boolean isMigration() { 00150 return migration; 00151 } 00152 00156 public void setAocreation(boolean b) { 00157 aocreation = b; 00158 } 00159 00163 public void setMigration(boolean b) { 00164 migration = b; 00165 } 00166 }
1.5.1
