org/objectweb/proactive/core/xml/handler/PassiveCompositeUnmarshaller.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.xml.handler;
00032
00033 import org.objectweb.proactive.core.xml.io.Attributes;
00034
00035
00044 public class PassiveCompositeUnmarshaller extends AbstractUnmarshallerDecorator {
00045     //
00046     // -- CONSTRUCTORS -----------------------------------------------
00047     //
00048     public PassiveCompositeUnmarshaller(boolean lenient) {
00049         super(lenient);
00050     }
00051
00052     public PassiveCompositeUnmarshaller() {
00053         super();
00054     }
00055
00056     //
00057     // -- PUBLIC METHODS -----------------------------------------------
00058     //
00059     //
00060     // -- implements UnmarshallerHandler ------------------------------------------------------
00061     //
00062     public Object getResultObject() throws org.xml.sax.SAXException {
00063         return null;
00064     }
00065
00066     public void startContextElement(String name, Attributes attributes)
00067         throws org.xml.sax.SAXException {
00068     }
00069
00070     //
00071     // -- PROTECTED METHODS ------------------------------------------------------
00072     //
00073     protected void notifyEndActiveHandler(String name,
00074         UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00075     }
00076
00077     //
00078     // -- PRIVATE METHODS ------------------------------------------------------
00079     //
00080     //
00081     // -- INNER CLASSES ------------------------------------------------------
00082     //
00083 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
