org/objectweb/proactive/benchmarks/timit/util/Parameter.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.benchmarks.timit.util;
00032
00039 public class Parameter {
00040
00041     public String className;
00042
00043     public String[] args;
00044
00045     public int run;
00046
00047     public String outputFile;
00048
00049     public String note;
00050
00051     public String name;
00052
00053     public XMLHelper xhp;
00054
00055     public String proActiveDescriptor;
00056
00057     public long timeout;
00058
00059     public String[] jvmArgs;
00060
00061     public int warmUpRuns;
00062
00087     public Parameter(XMLHelper xhp, String name, String className,
00088             String[] args, int run, String outputFile, String note,
00089             String proActiveDescriptor, long timeout, String[] jvmArgs,
00090             int warmUpRuns) {
00091
00092         this.xhp = xhp;
00093         this.name = name;
00094         this.className = className;
00095         this.args = args.clone();
00096         this.run = run;
00097         this.outputFile = outputFile;
00098         this.note = note;
00099         this.proActiveDescriptor = proActiveDescriptor;
00100         this.timeout = timeout;
00101         this.jvmArgs = jvmArgs.clone();
00102         this.warmUpRuns = warmUpRuns;
00103     }
00104
00105 }
Generated on Mon Jan 22 15:16:04 2007 for ProActive by  doxygen 1.5.1
