00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.mop; 00032 00033 import java.io.IOException; 00034 import java.io.InputStream; 00035 import java.io.ObjectInputStream; 00036 import java.io.ObjectStreamClass; 00037 00038 00039 public class PAObjectInputStream extends ObjectInputStream { 00040 public PAObjectInputStream(InputStream in) throws IOException { 00041 super(in); 00042 } 00043 00044 public PAObjectInputStream() throws IOException, SecurityException { 00045 super(); 00046 } 00047 00048 protected Class<?> resolveClass(ObjectStreamClass desc) 00049 throws IOException, ClassNotFoundException { 00050 try { 00051 super.resolveClass(desc); 00052 } catch (ClassNotFoundException e) { 00053 //it didn't work using standard resolving 00054 //let's see if the mop has seen this class before 00055 // System.out.println("Calling resolClass on " + desc); 00056 // System.out.println("Calling resolClass FAILED trying MOP "); 00057 return MOP.loadClass(desc.getName()); 00058 } 00059 return super.resolveClass(desc); 00060 } 00061 }
 1.5.1
