org/objectweb/proactive/p2p/service/node/P2PNode.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.p2p.service.node;
00032
00033 import java.io.Serializable;
00034
00035 import org.objectweb.proactive.core.node.Node;
00036
00037
00045 public class P2PNode implements Serializable {
00046     private Node node = null;
00047     private P2PNodeManager nodeManager = null;
00048
00049     public P2PNode(){
00050
00051     }
00052
00060     public P2PNode(Node node, P2PNodeManager nodeManager) {
00061         this.node = node;
00062         this.nodeManager = nodeManager;
00063     }
00064
00068     public Node getNode() {
00069         return this.node;
00070     }
00071
00075     public P2PNodeManager getNodeManager() {
00076         return this.nodeManager;
00077     }
00078 }
Generated on Mon Jan 22 15:16:11 2007 for ProActive by  doxygen 1.5.1
