00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.gen;
00032
00033 import java.io.Serializable;
00034 import java.util.ArrayList;
00035 import java.util.HashMap;
00036 import java.util.Iterator;
00037 import java.util.List;
00038 import java.util.Map;
00039 import java.util.Vector;
00040
00041 import javassist.CannotCompileException;
00042 import javassist.ClassPool;
00043 import javassist.CtClass;
00044 import javassist.CtField;
00045 import javassist.CtMethod;
00046 import javassist.CtNewMethod;
00047 import javassist.Modifier;
00048 import javassist.NotFoundException;
00049
00050 import org.objectweb.fractal.api.Component;
00051 import org.objectweb.proactive.core.component.ItfStubObject;
00052 import org.objectweb.proactive.core.component.ProActiveInterface;
00053 import org.objectweb.proactive.core.component.ProActiveInterfaceImpl;
00054 import org.objectweb.proactive.core.component.exceptions.InterfaceGenerationFailedException;
00055 import org.objectweb.proactive.core.component.type.ProActiveInterfaceType;
00056 import org.objectweb.proactive.core.mop.JavassistByteCodeStubBuilder;
00057 import org.objectweb.proactive.core.mop.StubObject;
00058 import org.objectweb.proactive.core.util.ClassDataCache;
00059
00068 public class OutputInterceptorClassGenerator
00069     extends AbstractInterfaceClassGenerator {
00070     List outputInterceptors;
00071     private static OutputInterceptorClassGenerator instance;
00072
00073     public static OutputInterceptorClassGenerator instance() {
00074         if (instance == null) {
00075             return new OutputInterceptorClassGenerator();
00076         } else {
00077             return instance;
00078         }
00079     }
00080
00081     public ProActiveInterface generateInterface(
00082         ProActiveInterface representative, List outputInterceptors)
00083         throws InterfaceGenerationFailedException {
00084         this.outputInterceptors = outputInterceptors;
00085         ProActiveInterface generated = generateInterface(representative.getFcItfName(),
00086                 representative.getFcItfOwner(),
00087                 (ProActiveInterfaceType) representative.getFcItfType(), false, true);
00088         ((StubObject) generated).setProxy(((StubObject) representative).getProxy());
00089         return generated;
00090     }
00091
00092     public ProActiveInterface generateInterface(final String interfaceName,
00093         Component owner, ProActiveInterfaceType interfaceType, boolean isInternal,
00094         boolean isFunctionalInterface)
00095         throws InterfaceGenerationFailedException {
00096         try {
00097             String representativeClassName = org.objectweb.proactive.core.component.gen.Utils.getOutputInterceptorClassName(interfaceName,
00098                     interfaceType.getFcItfSignature());
00099             Class generated_class;
00100
00101
00102             try {
00103                 generated_class = loadClass(representativeClassName);
00104             } catch (ClassNotFoundException cnfe) {
00105                 CtMethod[] reifiedMethods;
00106                 CtClass generatedCtClass = pool.makeClass(representativeClassName);
00107
00108
00109
00110
00111                 List interfacesToImplement = new ArrayList();
00112
00113
00114                 CtClass functional_itf = pool.get(interfaceType.getFcItfSignature());
00115                 generatedCtClass.addInterface(functional_itf);
00116
00117                 interfacesToImplement.add(functional_itf);
00118
00119
00120                 interfacesToImplement.add(pool.get(Serializable.class.getName()));
00121                 generatedCtClass.addInterface(pool.get(
00122                         Serializable.class.getName()));
00123
00124
00125                 generatedCtClass.addInterface(pool.get(
00126                         StubObject.class.getName()));
00127
00128
00129                 generatedCtClass.addInterface(pool.get(ItfStubObject.class.getName()));
00130                 Utils.createItfStubObjectMethods(generatedCtClass);
00131
00132
00133
00134                 List interfacesToImplementAndSuperInterfaces = new ArrayList(interfacesToImplement);
00135                 addSuperInterfaces(interfacesToImplementAndSuperInterfaces);
00136                 generatedCtClass.setSuperclass(pool.get(
00137                         ProActiveInterfaceImpl.class.getName()));
00138                 JavassistByteCodeStubBuilder.createStubObjectMethods(generatedCtClass);
00139                 CtField interfaceNameField = new CtField(ClassPool.getDefault()
00140        .get(String.class.getName()),
00141                         "interfaceName", generatedCtClass);
00142                 interfaceNameField.setModifiers(Modifier.STATIC);
00143                 generatedCtClass.addField(interfaceNameField,
00144                     "\"" + interfaceName + "\"");
00145
00146                 CtField methodsField = new CtField(pool.get(
00147                             "java.lang.reflect.Method[]"), "overridenMethods",
00148                         generatedCtClass);
00149                 methodsField.setModifiers(Modifier.STATIC);
00150                 generatedCtClass.addField(methodsField);
00151
00152
00153                 CtField genericTypesMappingField = new CtField(pool.get(
00154                 "java.util.Map"), "genericTypesMapping",
00155                 generatedCtClass);
00156
00157                 genericTypesMappingField.setModifiers(Modifier.STATIC);
00158                 generatedCtClass.addField(genericTypesMappingField);
00159
00160
00161                 CtField outputInterceptorsField = new CtField(pool.get(
00162                             List.class.getName()), "outputInterceptors",
00163                         generatedCtClass);
00164                 generatedCtClass.addField(outputInterceptorsField,
00165                     "new java.util.ArrayList();");
00166                 CtMethod outputInterceptorsSetter = CtNewMethod.setter("setOutputInterceptors",
00167                         outputInterceptorsField);
00168                 generatedCtClass.addMethod(outputInterceptorsSetter);
00169                 generatedCtClass.addInterface(pool.get(
00170                         OutputInterceptorHelper.class.getName()));
00171
00172
00173                 Map methodsToImplement = new HashMap();
00174                 List classesIndexer = new Vector();
00175
00176                 CtClass[] params;
00177                 CtClass itf;
00178
00179
00180                 Iterator it = interfacesToImplementAndSuperInterfaces.iterator();
00181                 while (it.hasNext()) {
00182                     itf = (CtClass) it.next();
00183                     if (!classesIndexer.contains(itf.getName())) {
00184                         classesIndexer.add(itf.getName());
00185                     }
00186
00187                     CtMethod[] declaredMethods = itf.getDeclaredMethods();
00188
00189                     for (int i = 0; i < declaredMethods.length; i++) {
00190                         CtMethod currentMethod = declaredMethods[i];
00191
00192
00193
00194                         String key = "";
00195                         key = key + currentMethod.getName();
00196                         params = currentMethod.getParameterTypes();
00197                         for (int k = 0; k < params.length; k++) {
00198                             key = key + params[k].getName();
00199                         }
00200
00201
00202                         methodsToImplement.put(key, currentMethod);
00203                     }
00204                 }
00205
00206                 reifiedMethods = (CtMethod[]) (methodsToImplement.values()
00207        .toArray(new CtMethod[methodsToImplement.size()]));
00208
00209
00210
00211
00212                 Vector v = new Vector();
00213                 int initialNumberOfMethods = reifiedMethods.length;
00214
00215                 for (int i = 0; i < initialNumberOfMethods; i++) {
00216                     if (JavassistByteCodeStubBuilder.checkMethod(
00217                                 reifiedMethods[i])) {
00218                         v.addElement(reifiedMethods[i]);
00219                     }
00220                 }
00221                 CtMethod[] validMethods = new CtMethod[v.size()];
00222                 v.copyInto(validMethods);
00223
00224                 reifiedMethods = validMethods;
00225
00226                 JavassistByteCodeStubBuilder.createStaticInitializer(generatedCtClass,
00227                     reifiedMethods, classesIndexer, interfaceType.getFcItfSignature(), null);
00228
00229                 createReifiedMethods(generatedCtClass, reifiedMethods,
00230                     isFunctionalInterface);
00231
00232
00233
00234
00235                 byte[] bytecode = generatedCtClass.toBytecode();
00236                 ClassDataCache.instance().addClassData(representativeClassName,
00237                     generatedCtClass.toBytecode());
00238                 if (logger.isDebugEnabled()) {
00239                     logger.debug("added " + representativeClassName +
00240                         " to cache");
00241                 }
00242                 if (logger.isDebugEnabled()) {
00243                     logger.debug("generated classes cache is : " +
00244                             ClassDataCache.instance().toString());
00245                 }
00246
00247
00248                 generated_class = Utils.defineClass(representativeClassName, bytecode);
00249             }
00250
00251             ProActiveInterfaceImpl reference = (ProActiveInterfaceImpl) generated_class.newInstance();
00252             reference.setFcItfName(interfaceName);
00253             reference.setFcItfOwner(owner);
00254             reference.setFcType(interfaceType);
00255             reference.setFcIsInternal(isInternal);
00256
00257             ((OutputInterceptorHelper) reference).setOutputInterceptors(outputInterceptors);
00258
00259             return reference;
00260         } catch (Exception e) {
00261                 throw new InterfaceGenerationFailedException(
00262                     "Cannot generate output interceptor on interface [" + interfaceName + "] with signature [" +  interfaceType.getFcItfSignature() + "] with javassist",
00263                     e);
00264         }
00265     }
00266
00267     protected static void createReifiedMethods(CtClass generatedClass,
00268         CtMethod[] reifiedMethods, boolean isFunctionalInterface)
00269         throws NotFoundException, CannotCompileException {
00270         for (int i = 0; i < reifiedMethods.length; i++) {
00271             CtClass[] paramTypes = reifiedMethods[i].getParameterTypes();
00272             String body = ("{\nObject[] parameters = new Object[" +
00273                 paramTypes.length + "];\n");
00274             for (int j = 0; j < paramTypes.length; j++) {
00275                 if (paramTypes[j].isPrimitive()) {
00276                     body += ("  parameters[" + j + "]=" +
00277                     JavassistByteCodeStubBuilder.wrapPrimitiveParameter(paramTypes[j],
00278                         "$" + (j + 1)) + ";\n");
00279                 } else {
00280                     body += ("  parameters[" + j + "]=$" + (j + 1) + ";\n");
00281                 }
00282             }
00283
00284             body += ("org.objectweb.proactive.core.mop.MethodCall methodCall = org.objectweb.proactive.core.mop.MethodCall.getComponentMethodCall(" +
00285             "(java.lang.reflect.Method)overridenMethods[" + i + "]" +
00286             ", parameters, null, interfaceName, senderItfID);\n");
00287
00288
00289             body += "java.util.ListIterator it = outputInterceptors.listIterator();\n";
00290             body += "while (it.hasNext()) {\n";
00291             body += "  ((org.objectweb.proactive.core.component.interception.OutputInterceptor) it.next()).beforeOutputMethodInvocation(methodCall);\n";
00292             body += "}\n";
00293
00294             CtClass returnType = reifiedMethods[i].getReturnType();
00295             if (returnType != CtClass.voidType) {
00296                 body += "Object result = ";
00297             }
00298             body += ("myProxy.reify(methodCall);\n");
00299
00300
00301             body += "it = outputInterceptors.listIterator();\n";
00302
00303
00304             body += "while (it.hasNext()) {\n";
00305             body += "it.next();\n";
00306             body += "}\n";
00307             body += "while (it.hasPrevious()) {\n";
00308             body += "  ((org.objectweb.proactive.core.component.interception.OutputInterceptor) it.previous()).afterOutputMethodInvocation(methodCall);\n";
00309             body += "}\n";
00310
00311
00312             String postWrap = null;
00313             String preWrap = null;
00314
00315             if (returnType != CtClass.voidType) {
00316                 if (!returnType.isPrimitive()) {
00317                     preWrap = "(" + returnType.getName() + ")";
00318                 } else {
00319
00320                     if (returnType.equals(CtClass.booleanType)) {
00321                         preWrap = "((Boolean)";
00322                         postWrap = ").booleanValue()";
00323                     }
00324                     if (returnType.equals(CtClass.byteType)) {
00325                         preWrap = "((Byte)";
00326                         postWrap = ").byteValue()";
00327                     }
00328                     if (returnType.equals(CtClass.charType)) {
00329                         preWrap = "((Character)";
00330                         postWrap = ").charValue()";
00331                     }
00332                     if (returnType.equals(CtClass.shortType)) {
00333                         preWrap = "((Short)";
00334                         postWrap = ").shortValue()";
00335                     }
00336                     if (returnType.equals(CtClass.intType)) {
00337                         preWrap = "((Integer)";
00338                         postWrap = ").intValue()";
00339                     }
00340                     if (returnType.equals(CtClass.longType)) {
00341                         preWrap = "((Long)";
00342                         postWrap = ").longValue()";
00343                     }
00344                     if (returnType.equals(CtClass.floatType)) {
00345                         preWrap = "((Float)";
00346                         postWrap = ").floatValue()";
00347                     }
00348                     if (returnType.equals(CtClass.doubleType)) {
00349                         preWrap = "((Double)";
00350                         postWrap = ").doubleValue()";
00351                     }
00352                 }
00353                 body += "return ";
00354                 if (preWrap != null) {
00355                     body += preWrap;
00356                 }
00357                 body += "result ";
00358             }
00359
00360             if (postWrap != null) {
00361                 body += postWrap;
00362             }
00363             body += ";";
00364             body += "\n}";
00365
00366
00367             CtMethod methodToGenerate = CtNewMethod.make(reifiedMethods[i].getReturnType(),
00368                     reifiedMethods[i].getName(),
00369                     reifiedMethods[i].getParameterTypes(),
00370                     reifiedMethods[i].getExceptionTypes(), body, generatedClass);
00371             generatedClass.addMethod(methodToGenerate);
00372         }
00373     }
00374 }
