org/objectweb/proactive/core/process/oar/OARSubProcess.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.process.oar;
00032
00033 import java.util.ArrayList;
00034 import java.util.regex.Matcher;
00035 import java.util.regex.Pattern;
00036
00037 import org.objectweb.proactive.core.process.AbstractExternalProcessDecorator;
00038 import org.objectweb.proactive.core.process.ExternalProcess;
00039 import org.objectweb.proactive.core.process.JVMProcessImpl;
00040 import org.objectweb.proactive.core.process.MessageSink;
00041 import org.objectweb.proactive.core.process.UniversalProcess;
00042
00043
00066 public class OARSubProcess extends AbstractExternalProcessDecorator {
00067     private static final String FILE_SEPARATOR = System.getProperty(
00068             "file.separator");
00069     public final static String DEFAULT_OARSUBPATH = "/usr/local/bin/oarsub";
00070     private static final String DEFAULT_SCRIPT_LOCATION = System.getProperty(
00071             "user.home") + FILE_SEPARATOR + "ProActive" + FILE_SEPARATOR +
00072         "scripts" + FILE_SEPARATOR + "unix" + FILE_SEPARATOR + "cluster" +
00073         FILE_SEPARATOR + "oarStartRuntime.sh ";
00074     protected static final String DEFAULT_HOSTS_NUMBER = "1";
00075     protected String hostNumber = DEFAULT_HOSTS_NUMBER;
00076     protected String weight = "2";
00077     protected String scriptLocation = DEFAULT_SCRIPT_LOCATION;
00078     protected String interactive = "false";
00079     protected int jobID;
00080     protected String queueName;
00081     protected String accessProtocol = "rsh";
00082     protected String resources;
00083
00084     //protected String properties;
00085     public OARSubProcess() {
00086         super();
00087         setCompositionType(GIVE_COMMAND_AS_PARAMETER);
00088         this.hostname = null;
00089         this.command_path = DEFAULT_OARSUBPATH;
00090     }
00091
00092     public OARSubProcess(ExternalProcess targetProcess) {
00093         super(targetProcess);
00094         this.hostname = null;
00095         this.command_path = DEFAULT_OARSUBPATH;
00096     }
00097
00098     //  ----------------------------------------------------------------------------------------
00099     //-----------------------Extends AbstractExternalProcessDecorator-------------------------
00100     //  ----------------------------------------------------------------------------------------
00101
00102     public void setOutputMessageSink(MessageSink outputMessageSink) {
00103         if (outputMessageSink == null) {
00104             super.setOutputMessageSink(new SimpleMessageSink());
00105         } else {
00106             super.setOutputMessageSink(outputMessageSink);
00107         }
00108     }
00109
00113     public String getProcessId() {
00114         return "oar_" + targetProcess.getProcessId();
00115     }
00116
00120     public int getNodeNumber() {
00121         if (hostNumber.equals("all")) {
00122             return UniversalProcess.UNKNOWN_NODE_NUMBER;
00123         }
00124
00125         return (new Integer(hostNumber).intValue() * new Integer(weight).intValue());
00126     }
00127
00131     public UniversalProcess getFinalProcess() {
00132         checkStarted();
00133         return targetProcess.getFinalProcess();
00134     }
00135
00140     public void setScriptLocation(String location) {
00141         checkStarted();
00142         //     if (location != null) {
00143         this.scriptLocation = location;
00144         //    }
00145     }
00146
00152     public void setAccessProtocol(String accessProtocol) {
00153         this.accessProtocol = accessProtocol;
00154     }
00155
00161     public void setResources(String res) {
00162         checkStarted();
00163         if (res != null) {
00164             this.resources = res;
00165             parseRes(res);
00166         }
00167     }
00168
00169     //    /**
00170     //     * Sets the value of the hostList parameter with the given value
00171     //     * Not yet included in the oar command
00172     //     * @param hostList
00173     //     */
00174     //    public void setProperties(String props) {
00175     //        checkStarted();
00176     //        if (props != null) {
00177     //            this.properties = checkProperties(props);
00178     //        }
00179     //    }
00180
00186     public void setInteractive(String interactive) {
00187         this.interactive = interactive;
00188     }
00189
00195     public void setQueueName(String queueName) {
00196         checkStarted();
00197         if (queueName == null) {
00198             throw new NullPointerException();
00199         }
00200         this.queueName = queueName;
00201     }
00202
00203     protected String parseHostname(String message) {
00204         //To be modified for OAR, does not work with the present code
00205         String result = new String();
00206         if (logger.isDebugEnabled()) {
00207             logger.debug("parseHostname() analyzing " + message);
00208         }
00209         java.util.StringTokenizer st = new java.util.StringTokenizer(message);
00210         if (st.countTokens() < 2) {
00211             return null; //at least two tokens
00212         }
00213         if (!":".equals(st.nextToken())) {
00214             return null; //should start with :
00215         }
00216
00217         while (st.hasMoreTokens()) {
00218             result += (st.nextToken());
00219             result += " ";
00220         }
00221         return result;
00222     }
00223
00224     //    protected String internalBuildCommand() {
00225     //        return buildEnvironmentCommand(); // + buildPSubCommand();
00226     //    }
00227     protected void internalStartProcess(String commandToExecute)
00228         throws java.io.IOException {
00229         ArrayList<String> al = new ArrayList<String>();
00230
00231         //we divide the command into tokens
00232         //it's basically 3 blocks, the script path, the option and the rest
00233         Pattern p = Pattern.compile("(.*) .*(-c).*'(.*)'");
00234         Matcher m = p.matcher(command);
00235         if (!m.matches()) {
00236             System.err.println("Could not match command ");
00237             System.err.println(commandToExecute);
00238         }
00239         for (int i = 1; i <= m.groupCount(); i++) {
00240             //            System.out.println(m.group(i));
00241             al.add(m.group(i));
00242         }
00243         String[] command = al.toArray(new String[] {  });
00244
00245         try {
00246             externalProcess = Runtime.getRuntime().exec(command);
00247             java.io.BufferedReader in = new java.io.BufferedReader(new java.io.InputStreamReader(
00248                         externalProcess.getInputStream()));
00249             java.io.BufferedReader err = new java.io.BufferedReader(new java.io.InputStreamReader(
00250                         externalProcess.getErrorStream()));
00251             java.io.BufferedWriter out = new java.io.BufferedWriter(new java.io.OutputStreamWriter(
00252                         externalProcess.getOutputStream()));
00253             handleProcess(in, out, err);
00254         } catch (java.io.IOException e) {
00255             isFinished = true;
00256             //throw e;
00257             e.printStackTrace();
00258         }
00259     }
00260
00266     protected String internalBuildCommand() {
00267         StringBuilder oarsubCommand = new StringBuilder();
00268         oarsubCommand.append(
00269             "/bin/sh -c  'echo for i in \\`cat \\$OAR_NODEFILE\\` \\; do " +
00270             accessProtocol + " \\$i  ");
00271         oarsubCommand.append(targetProcess.getCommand());
00272         oarsubCommand.append(" \\&  done  \\; wait > ");
00273         oarsubCommand.append(scriptLocation).append(" ; ");
00274         oarsubCommand.append(command_path);
00275         oarsubCommand.append(" ");
00276         if (resources != null) {
00277             oarsubCommand.append("-l " + resources).append(" ");
00278         }
00279
00280         //To implement if needed
00281         //        if(properties != null){
00282         //            oarsubCommand.append("-p "+properties).append(" ");
00283         //        }
00284         oarsubCommand.append(scriptLocation).append(" '");
00285         if (logger.isDebugEnabled()) {
00286             logger.debug("oarsub command is " + oarsubCommand.toString());
00287         }
00288         return oarsubCommand.toString();
00289     }
00290
00294     private void parseRes(String res) {
00295         String[] resTab = res.split(",");
00296         for (int i = 0; i < resTab.length; i++) {
00297             if (!(resTab[i].indexOf("nodes") < 0)) {
00298                 hostNumber = resTab[i].substring(resTab[i].indexOf("=") + 1,
00299                         resTab[i].length());
00300             }
00301             if (!(resTab[i].indexOf("weight") < 0)) {
00302                 weight = resTab[i].substring(resTab[i].indexOf("=") + 1,
00303                         resTab[i].length());
00304             }
00305         }
00306     }
00307
00308     public static void main(String[] args) {
00309         System.out.println("Testing OARSubProcess");
00310         JVMProcessImpl p = new JVMProcessImpl();
00311         OARSubProcess oar = new OARSubProcess(p);
00312         oar.setResources("nodes=2");
00313         System.out.println(oar.buildCommand());
00314     }
00315 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
