00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.process.oar;
00032
00033 import java.io.Serializable;
00034 import java.util.ArrayList;
00035 import java.util.regex.Matcher;
00036 import java.util.regex.Pattern;
00037
00038 import org.objectweb.proactive.core.process.AbstractExternalProcessDecorator;
00039 import org.objectweb.proactive.core.process.ExternalProcess;
00040 import org.objectweb.proactive.core.process.JVMProcessImpl;
00041 import org.objectweb.proactive.core.process.UniversalProcess;
00042
00043
00053 public class OARGRIDSubProcess extends AbstractExternalProcessDecorator {
00054 private static final String FILE_SEPARATOR = System.getProperty(
00055 "file.separator");
00056 public final static String DEFAULT_OARGRIDSUBPATH = "/usr/local/bin/oargridsub";
00057 private static final String DEFAULT_SCRIPT_LOCATION = System.getProperty(
00058 "user.home") + FILE_SEPARATOR + "ProActive" + FILE_SEPARATOR +
00059 "scripts" + FILE_SEPARATOR + "unix" + FILE_SEPARATOR + "cluster" +
00060 FILE_SEPARATOR + "oarGRIDStartRuntime.sh ";
00061 protected static final int DEFAULT_HOSTS_NUMBER = 1;
00062 protected static final int DEFAULT_WEIGHT = 1;
00063 protected static final String DEFAULT_WALLTIME = "01:00:00";
00064 protected OarSite[] oarsite = null;
00065 protected String scriptLocation = DEFAULT_SCRIPT_LOCATION;
00066 protected int jobID;
00067 protected String queueName = "default";
00068 protected String accessProtocol = "ssh";
00069 protected String resources = "";
00070 protected String walltime = DEFAULT_WALLTIME;
00071
00072 public OARGRIDSubProcess() {
00073 super();
00074 setCompositionType(GIVE_COMMAND_AS_PARAMETER);
00075 this.hostname = null;
00076 this.command_path = DEFAULT_OARGRIDSUBPATH;
00077 }
00078
00079 public OARGRIDSubProcess(ExternalProcess targetProcess) {
00080 super(targetProcess);
00081 this.hostname = null;
00082 this.command_path = DEFAULT_OARGRIDSUBPATH;
00083 }
00084
00088 public String getProcessId() {
00089 return "oargrid_" + targetProcess.getProcessId();
00090 }
00091
00095 public int getNodeNumber() {
00096 int num = 0;
00097
00098
00099 for (int i = 0; i < oarsite.length; i++) {
00100 if (oarsite[i].getNodes() == UniversalProcess.UNKNOWN_NODE_NUMBER) {
00101 return UniversalProcess.UNKNOWN_NODE_NUMBER;
00102 }
00103 num += (oarsite[i].getNodes() * oarsite[i].getWeight());
00104 }
00105 return num;
00106 }
00107
00111 public UniversalProcess getFinalProcess() {
00112 checkStarted();
00113 return targetProcess.getFinalProcess();
00114 }
00115
00116 public String getWallTime() {
00117 return walltime;
00118 }
00119
00125 public void setScriptLocation(String location) {
00126 checkStarted();
00127
00128 this.scriptLocation = location;
00129
00130 }
00131
00138 public void setAccessProtocol(String accessProtocol) {
00139 this.accessProtocol = accessProtocol;
00140 }
00141
00149 public void setResources(String resources) {
00150 checkStarted();
00151 if (resources != null) {
00152 ArrayList<OarSite> al = new ArrayList<OarSite>();
00153 this.resources = resources;
00154 String[] resTab = resources.split(",");
00155 for (int i = 0; i < resTab.length; i++)
00156 al.add(new OarSite(resTab[i]));
00157
00158 this.oarsite = al.toArray((new OarSite[] { }));
00159 }
00160 }
00161
00168 public void setQueueName(String queueName) {
00169 checkStarted();
00170 if (queueName == null) {
00171 throw new NullPointerException();
00172 }
00173 this.queueName = queueName;
00174 }
00175
00176 public void setWallTime(String walltime) {
00177 checkStarted();
00178 if (walltime == null) {
00179 throw new NullPointerException();
00180 }
00181 this.walltime = walltime;
00182 }
00183
00184 protected void internalStartProcess(String commandToExecute)
00185 throws java.io.IOException {
00186 ArrayList<String> al = new ArrayList<String>();
00187
00188
00189
00190 Pattern p = Pattern.compile("(.*) .*(-c).*'(.*)'");
00191 Matcher m = p.matcher(command);
00192 if (!m.matches()) {
00193 System.err.println("Could not match command ");
00194 System.err.println(command);
00195 }
00196 for (int i = 1; i <= m.groupCount(); i++) {
00197
00198 al.add(m.group(i));
00199 }
00200 String[] command = al.toArray(new String[] { });
00201
00202 try {
00203 externalProcess = Runtime.getRuntime().exec(command);
00204 java.io.BufferedReader in = new java.io.BufferedReader(new java.io.InputStreamReader(
00205 externalProcess.getInputStream()));
00206 java.io.BufferedReader err = new java.io.BufferedReader(new java.io.InputStreamReader(
00207 externalProcess.getErrorStream()));
00208 java.io.BufferedWriter out = new java.io.BufferedWriter(new java.io.OutputStreamWriter(
00209 externalProcess.getOutputStream()));
00210 handleProcess(in, out, err);
00211 } catch (java.io.IOException e) {
00212 isFinished = true;
00213
00214 e.printStackTrace();
00215 }
00216 }
00217
00223 protected String internalBuildCommand() {
00224 StringBuilder oarsubCommand = new StringBuilder();
00225 oarsubCommand.append(
00226 "/bin/sh -c 'echo for i in \\`cat \\$OAR_NODEFILE\\` \\; do " +
00227 accessProtocol + " \\$i ");
00228
00229 oarsubCommand.append(targetProcess.getCommand());
00230 oarsubCommand.append(" \\& done \\; wait > ");
00231 oarsubCommand.append(scriptLocation).append(" ; ");
00232
00233
00234 for (int i = 0; i < oarsite.length; i++)
00235 oarsubCommand.append(getScpRunTimeStr(oarsite[i]));
00236
00237 oarsubCommand.append(command_path);
00238 oarsubCommand.append(" -q ");
00239 oarsubCommand.append(this.queueName);
00240 oarsubCommand.append(" -w ");
00241 oarsubCommand.append(this.walltime);
00242 oarsubCommand.append(" -p ");
00243 oarsubCommand.append(this.scriptLocation);
00244
00245 if (resources != null) {
00246 oarsubCommand.append(" ").append(resources).append(" ");
00247 }
00248 oarsubCommand.append("'");
00249
00250 if (logger.isDebugEnabled()) {
00251 logger.debug("oarsub command is " + oarsubCommand.toString());
00252 }
00253 System.err.println(oarsubCommand);
00254 return oarsubCommand.toString();
00255 }
00256
00266 private String getScpRunTimeStr(OarSite oarsite) {
00267 if (oarsite == null) {
00268 return "";
00269 }
00270 if ((oarsite.getClusterFrontEndName() == null) ||
00271 (oarsite.getClusterFrontEndName() == "")) {
00272 return "";
00273 }
00274
00275 StringBuilder str = new StringBuilder();
00276
00277 str.append("scp -p ");
00278 str.append(this.scriptLocation);
00279 str.append(" ");
00280 str.append(oarsite.getClusterFrontEndName());
00281 str.append(":" + this.scriptLocation + " ; ");
00282 return str.toString();
00283 }
00284
00285 public class OarSite implements Serializable {
00286 private String clusterName;
00287 private String clusterFrontEndName;
00288 private int nodes;
00289 private int weight;
00290
00297 public OarSite(String resource) {
00298 setResource(resource);
00299
00300
00301 if (clusterName.equalsIgnoreCase("idpot")) {
00302
00303 clusterFrontEndName = "caddo.imag.fr";
00304 } else if (clusterName.equalsIgnoreCase("sophia")) {
00305 clusterFrontEndName = "oar.sophia.grid5000.fr";
00306 } else if (clusterName.equalsIgnoreCase("gdx")) {
00307
00308 clusterFrontEndName = "devgdx002.orsay.grid5000.fr";
00309 } else if (clusterName.equalsIgnoreCase("lyon")) {
00310 clusterFrontEndName = "oar.lyon.grid5000.fr";
00311 } else if (clusterName.equalsIgnoreCase("toulouse")) {
00312 clusterFrontEndName = "oar.toulouse.grid5000.fr";
00313 } else if (clusterName.equalsIgnoreCase("parasol")) {
00314 clusterFrontEndName = "oar.rennes.grid5000.fr";
00315 } else if (clusterName.equalsIgnoreCase("paraci")) {
00316
00317 clusterFrontEndName = "dev-xeon.rennes.grid5000.fr";
00318 } else if (clusterName.equalsIgnoreCase("tartopom")) {
00319
00320 clusterFrontEndName = "dev-powerpc.rennes.grid5000.fr";
00321 } else if (clusterName.equalsIgnoreCase("icluster2")) {
00322 clusterFrontEndName = "ita101.imag.fr";
00323 }
00324
00325 else {
00326 System.out.println(
00327 "clusterFrontEndName not found for cluster: " +
00328 clusterName);
00329 if (logger.isDebugEnabled()) {
00330 logger.debug("clusterFrontEndName not found for cluster: " +
00331 clusterName);
00332 }
00333 }
00334 }
00335
00344 public OarSite(String resource, String clusterFrontEndName) {
00345 this.clusterFrontEndName = clusterFrontEndName;
00346 setResource(resource);
00347 }
00348
00355 public void setResource(String resource) {
00356 this.clusterName = "";
00357 this.clusterFrontEndName = "";
00358 nodes = OARGRIDSubProcess.DEFAULT_HOSTS_NUMBER;
00359 weight = OARGRIDSubProcess.DEFAULT_WEIGHT;
00360
00361 String[] resTab = resource.split(":");
00362 for (int i = 0; i < resTab.length; i++) {
00363
00364 if (resTab[i].indexOf("=") < 0) {
00365 clusterName = resTab[i];
00366 } else if (resTab[i].indexOf("nodes=") >= 0) {
00367 String count = resTab[i].substring(resTab[i].indexOf("=") +
00368 1);
00369 if (count.equals("all")) {
00370 nodes = UniversalProcess.UNKNOWN_NODE_NUMBER;
00371 } else {
00372 nodes = Integer.parseInt(count);
00373 }
00374 } else if (resTab[i].indexOf("weight=") >= 0) {
00375 weight = Integer.parseInt(resTab[i].substring(resTab[i].indexOf(
00376 "=") + 1));
00377 }
00378 }
00379 }
00380
00381 public String getResource() {
00382 return this.clusterName + ":nodes=" + this.nodes + ":weight=" +
00383 this.weight;
00384 }
00385
00386 public String getClusterFrontEndName() {
00387 return clusterFrontEndName;
00388 }
00389
00390 public void setClusterFrontEndName(String clusterFrontEndName) {
00391 this.clusterFrontEndName = clusterFrontEndName;
00392 }
00393
00394 public String getClusterName() {
00395 return clusterName;
00396 }
00397
00398 public void setClusterName(String clusterName) {
00399 this.clusterName = clusterName;
00400 }
00401
00402 public int getNodes() {
00403 return nodes;
00404 }
00405
00406 public void setNodes(int nodes) {
00407 this.nodes = nodes;
00408 }
00409
00410 public int getWeight() {
00411 return weight;
00412 }
00413
00414 public void setWeight(int weight) {
00415 this.weight = weight;
00416 }
00417 }
00418
00419 public static void main(String[] args) {
00420 System.out.println("Testing OARGRIDSubProcess");
00421 JVMProcessImpl p = new JVMProcessImpl();
00422 OARGRIDSubProcess oargrid = new OARGRIDSubProcess(p);
00423 oargrid.setResources("sophia:nodes=2:weight=3,idpot:nodes=10");
00424 System.out.println(oargrid.buildCommand());
00425 System.out.println(oargrid.getCommand());
00426 }
00427 }
