00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.util; 00032 00033 import java.lang.reflect.Method; 00034 import java.lang.reflect.TypeVariable; 00035 import java.util.Map; 00036 00037 import org.objectweb.proactive.core.mop.MethodCall; 00038 import org.objectweb.proactive.core.mop.Proxy; 00039 00049 public class NonFunctionalServices { 00050 00051 static Class nonFunctionalServicesClass = null; 00052 static Method terminateAOMethod = null; 00053 static Method terminateAOImmediatelyMethod = null; 00054 static Class paramTypes[]; 00055 00056 00057 static { 00058 00059 try { 00060 nonFunctionalServicesClass = java.lang.Class.forName ("org.objectweb.proactive.core.util.NonFunctionalServices"); 00061 paramTypes = new Class[1]; 00062 paramTypes [0] = java.lang.Class.forName ("org.objectweb.proactive.core.mop.Proxy"); 00063 terminateAOMethod = nonFunctionalServicesClass.getMethod("_terminateAO", paramTypes); 00064 terminateAOImmediatelyMethod = nonFunctionalServicesClass.getMethod("_terminateAOImmediately", paramTypes); 00065 } catch (ClassNotFoundException e) { 00066 e.printStackTrace(); 00067 } 00068 catch (SecurityException es) { 00069 es.printStackTrace(); 00070 00071 }catch (NoSuchMethodException en) { 00072 en.printStackTrace(); 00073 } 00074 } 00075 00081 public static void terminateAO (Proxy proxy) throws Throwable { 00082 proxy.reify(MethodCall.getMethodCall(terminateAOMethod, paramTypes, (Map<TypeVariable, Class>)null)); 00083 } 00084 00091 public static void terminateAOImmediately(Proxy proxy) throws Throwable { 00092 proxy.reify(MethodCall.getMethodCall(terminateAOImmediatelyMethod, paramTypes, (Map<TypeVariable, Class>)null)); 00093 } 00094 00100 public void _terminateAO(Proxy proxy){} 00101 00108 public void _terminateAOImmediately(Proxy proxy) {} 00109 }
1.5.1
