00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.body.request;
00032
00033 import java.io.Serializable;
00034 import java.util.AbstractList;
00035 import java.util.Vector;
00036
00037
00059 public class NonFunctionalRequestsProcessor implements RequestProcessor, Serializable {
00060
00061
00062         private static final long serialVersionUID = 1L;
00063         private AbstractList<Request> nfRequestsQueue;
00064         private RequestFilter immediateNFResquestFilter;
00065     private RequestFilter priorityNFRequestFilter;
00066     private int immediateNFReqNumber, priorityNFReqNumber;
00067
00068
00069         public NonFunctionalRequestsProcessor() {
00070                 nfRequestsQueue = new Vector<Request>();
00071                 this.immediateNFResquestFilter = new ImmediateNFRequestFilter();
00072         this.priorityNFRequestFilter = new PriorityNFRequestFilter();
00073         immediateNFReqNumber = 0;
00074         priorityNFReqNumber = 0;
00075         }
00076
00077
00078
00084         public synchronized void  addToNFRequestsQueue(Request request) {
00085                 if(immediateNFResquestFilter.acceptRequest(request)) {
00086                         nfRequestsQueue.add(immediateNFReqNumber,request);
00087                         immediateNFReqNumber ++;
00088                 } else if (priorityNFRequestFilter.acceptRequest(request)){
00089                         nfRequestsQueue.add(immediateNFReqNumber + priorityNFReqNumber, request);
00090                         priorityNFReqNumber ++;
00091                 }
00092         }
00093
00099         public synchronized Request getOldestPriorityNFRequest(boolean remove) {
00100                 Request request;
00101                 if(nfRequestsQueue.isEmpty()) {
00102                         return null;
00103                 }else if (remove){
00104                         request = nfRequestsQueue.remove(0);
00105                         if(immediateNFReqNumber > 0){
00106                                 immediateNFReqNumber --;
00107                         }else {
00108                                 priorityNFReqNumber --;
00109                         }
00110                         return request;
00111                 }else {
00112                         return nfRequestsQueue.get(0);
00113                 }
00114         }
00115
00116
00122         public synchronized Request getYoungestPriorityNFRequest(boolean remove) {
00123                 Request request;
00124
00125                 if(nfRequestsQueue.isEmpty()) {
00126                         return null;
00127                 }else if (remove){
00128                         if(immediateNFReqNumber != 0){
00129                                 request = nfRequestsQueue.remove(immediateNFReqNumber);
00130                                 immediateNFReqNumber --;
00131                                 return request;
00132                         }else {
00133                                 request = nfRequestsQueue.remove(priorityNFReqNumber);
00134                                 priorityNFReqNumber --;
00135                                 return request;
00136                         }
00137                 }else {
00138                         if(immediateNFReqNumber != 0){
00139                                 return nfRequestsQueue.get(immediateNFReqNumber);
00140                         }else {
00141                                 return nfRequestsQueue.get(priorityNFReqNumber);
00142                         }
00143                 }
00144         }
00145
00146
00147         public synchronized boolean isEmpty() {
00148                 return (immediateNFReqNumber == 0 && priorityNFReqNumber == 0);
00149         }
00150
00151
00152         public synchronized String toString() {
00153                 StringBuffer sb = new StringBuffer("NFRequests Queue : ");
00154                 sb.append("--- NonFunctionalRequestQueue n=").append(nfRequestsQueue.size()).append("   requests --- ->\n");
00155                 int count = 0;
00156                 java.util.Iterator<Request> iterator = nfRequestsQueue.iterator();
00157                 while (iterator.hasNext()) {
00158                         Request currentrequest = iterator.next();
00159                         sb.append(count).append("--> ")
00160                         .append(currentrequest.getMethodName()).append("\n");
00161                         count++;
00162                 }
00163                 sb.append("--- End NonFunctionalRequestQueue ---");
00164                 return sb.toString();
00165         }
00166
00167         public int processRequest(Request request) {
00168                 if((request.getNFRequestPriority() == Request.NFREQUEST_IMMEDIATE_PRIORITY )|| (request.getNFRequestPriority() == Request.NFREQUEST_PRIORITY)){
00169                         nfRequestsQueue.add(request);
00170                 }
00171                 return RequestProcessor.KEEP;
00172         }
00173
00174
00175
00176
00186     protected class ImmediateNFRequestFilter implements RequestFilter, Serializable {
00190                 private static final long serialVersionUID = 1L;
00191
00192                 public boolean acceptRequest(Request request) {
00193                 return (request.isFunctionalRequest()
00194                                 && (request.getNFRequestPriority() == Request.NFREQUEST_IMMEDIATE_PRIORITY));
00195         }
00196     }
00197
00198
00208     protected class PriorityNFRequestFilter implements RequestFilter, Serializable {
00212                 private static final long serialVersionUID = 1L;
00213
00214                 public boolean acceptRequest(Request request) {
00215                 return (request.isFunctionalRequest()
00216                                 && (request.getNFRequestPriority() == Request.NFREQUEST_PRIORITY));
00217         }
00218     }
00219
00229     protected class NoPriorityNFRequestFilter implements RequestFilter, Serializable {
00233                 private static final long serialVersionUID = 1L;
00234
00235                 public boolean acceptRequest(Request request) {
00236                 return (request.isFunctionalRequest()
00237                                 && (request.getNFRequestPriority() == Request.NFREQUEST_NO_PRIORITY));
00238         }
00239
00240     }
00241
00242
00243
00244
00245
00246
00247
00248
00249
00250
00251 }
