org/objectweb/proactive/core/exceptions/NonFunctionalException.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.exceptions;
00032
00033 import java.io.Serializable;
00034
00035 import org.objectweb.proactive.ProActive;
00036
00037
00042 public class NonFunctionalException extends RuntimeException
00043     implements Serializable {
00044     private String nodeURL;
00045
00046     public NonFunctionalException(String message, Throwable cause) {
00047         super(message, cause);
00048         nodeURL = ProActive.getBodyOnThis().getNodeURL();
00049     }
00050
00051     public String getNodeURL() {
00052         return nodeURL;
00053     }
00054
00055     private static String getSmallName(Class c) {
00056         String smallName = c.getName();
00057         int lastDot = smallName.lastIndexOf('.');
00058         if (lastDot > 0) {
00059             smallName = smallName.substring(lastDot + 1);
00060         }
00061
00062         return smallName;
00063     }
00064
00065     public String toString() {
00066         String str = "NFE[" + getNodeURL() + "]";
00067         for (Throwable cause = this; cause != null; cause = cause.getCause()) {
00068             str += (": " + getSmallName(cause.getClass()) + ": " +
00069             cause.getMessage());
00070         }
00071
00072         return str;
00073     }
00074 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
