00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.node;
00032
00033 import java.net.UnknownHostException;
00034 import java.rmi.AlreadyBoundException;
00035
00036 import org.apache.log4j.Logger;
00037 import org.objectweb.proactive.ProActive;
00038 import org.objectweb.proactive.core.ProActiveException;
00039 import org.objectweb.proactive.core.UniqueID;
00040 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00041 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00042 import org.objectweb.proactive.core.runtime.ProActiveRuntimeImpl;
00043 import org.objectweb.proactive.core.runtime.RuntimeFactory;
00044 import org.objectweb.proactive.core.util.UrlBuilder;
00045 import org.objectweb.proactive.core.util.log.Loggers;
00046 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00047 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00048
00049
00077 public class NodeFactory {
00078 protected static Logger logger = ProActiveLogger.getLogger(Loggers.DEPLOYMENT);
00079 private static final String DEFAULT_NODE_NAME;
00080 private static Node defaultNode = null;
00081
00082 static {
00083 ProActiveConfiguration.load();
00084
00085 String protocol = UrlBuilder.checkProtocol(System.getProperty(
00086 "proactive.communication.protocol"));
00087 String port = System.getProperty("proactive.rmi.port");
00088
00089 if (port != null) {
00090 DEFAULT_NODE_NAME = UrlBuilder.buildUrl("localhost", "Node",
00091 protocol, new Integer(port).intValue());
00092 } else {
00093 DEFAULT_NODE_NAME = UrlBuilder.buildUrl("localhost", "Node",
00094 protocol);
00095 }
00096 }
00097
00098
00099
00100
00101
00102
00103 public static synchronized Node getDefaultNode() throws NodeException {
00104 String nodeURL = null;
00105
00106 ProActiveRuntime defaultRuntime = null;
00107 String jobID = ProActive.getJobId();
00108 ProActiveSecurityManager securityManager = null;
00109
00110 if (defaultNode == null) {
00111 try {
00112 defaultRuntime = RuntimeFactory.getDefaultRuntime();
00113 nodeURL = defaultRuntime.createLocalNode(DEFAULT_NODE_NAME +
00114 Integer.toString(ProActiveRuntimeImpl.getNextInt()),
00115 false, securityManager, "DefaultVN", jobID);
00116 } catch (ProActiveException e) {
00117 throw new NodeException("Cannot create the default Node", e);
00118 } catch (AlreadyBoundException e) {
00119 getDefaultNode();
00120 }
00121
00122 defaultNode = new NodeImpl(defaultRuntime, nodeURL,
00123 UrlBuilder.checkProtocol(System.getProperty(
00124 "proactive.communication.protocol")), jobID );
00125 }
00126
00127 return defaultNode;
00128 }
00129
00134 public static boolean isNodeLocal(Node node) {
00135 return node.getNodeInformation().getVMID()
00136 .equals(UniqueID.getCurrentVMID());
00137 }
00138
00153 public static Node createNode(String nodeURL)
00154 throws NodeException, AlreadyBoundException {
00155 return createNode(nodeURL, false, null, null);
00156 }
00157
00173 public static Node createNode(String url, boolean replacePreviousBinding,
00174 ProActiveSecurityManager psm, String vnname)
00175 throws NodeException, AlreadyBoundException {
00176 ProActiveRuntime proActiveRuntime;
00177 String nodeURL;
00178 String jobID = ProActive.getJobId();
00179
00180 if (logger.isDebugEnabled()) {
00181 logger.debug("NodeFactory: createNode(" + url + ")");
00182 }
00183
00184
00185 String protocol = UrlBuilder.getProtocol(url);
00186
00187
00188
00189 try {
00190 proActiveRuntime = RuntimeFactory.getProtocolSpecificRuntime(protocol);
00191 nodeURL = proActiveRuntime.createLocalNode(url,
00192 replacePreviousBinding, psm, vnname, jobID);
00193 } catch (ProActiveException e) {
00194 throw new NodeException("Cannot create a Node based on " + url, e);
00195 }
00196
00197 Node node = new NodeImpl(proActiveRuntime, nodeURL, protocol, jobID);
00198
00199 return node;
00200 }
00201
00209 public static Node getNode(String nodeURL) throws NodeException {
00210 ProActiveRuntime proActiveRuntime;
00211 String url;
00212 String jobID;
00213
00214 if (logger.isDebugEnabled()) {
00215 logger.debug("NodeFactory: getNode() for " + nodeURL);
00216 }
00217
00218
00219 String protocol = UrlBuilder.getProtocol(nodeURL);
00220
00221
00222 try {
00223 url = UrlBuilder.checkUrl(nodeURL);
00224 proActiveRuntime = RuntimeFactory.getRuntime(url, protocol);
00225 jobID = proActiveRuntime.getJobID(url);
00226 } catch (ProActiveException e) {
00227 throw new NodeException("Cannot get the node based on " + nodeURL, e);
00228 } catch (UnknownHostException e) {
00229 throw new NodeException("Cannot get the node based on " + nodeURL, e);
00230 }
00231
00232 Node node = new NodeImpl(proActiveRuntime, url, protocol, jobID);
00233
00234 return node;
00235 }
00236
00242 public static void killNode(String nodeURL) throws NodeException {
00243 ProActiveRuntime proActiveRuntime;
00244 String url;
00245
00246 String protocol = UrlBuilder.getProtocol(nodeURL);
00247
00248 try {
00249 url = UrlBuilder.checkUrl(nodeURL);
00250 proActiveRuntime = RuntimeFactory.getRuntime(url, protocol);
00251 proActiveRuntime.killNode(url);
00252 } catch (ProActiveException e) {
00253 throw new NodeException("Cannot get the node based on " + nodeURL, e);
00254 } catch (UnknownHostException e) {
00255 throw new NodeException("Cannot get the node based on " + nodeURL, e);
00256 }
00257 }
00258 }
