00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.event; 00032 00033 import org.objectweb.proactive.core.descriptor.data.VirtualNode; 00034 import org.objectweb.proactive.core.node.Node; 00035 00036 00037 public class NodeCreationEventProducerImpl extends AbstractEventProducer 00038 implements NodeCreationEventProducer { 00039 public NodeCreationEventProducerImpl() { 00040 super(false, false); 00041 } 00042 00043 // 00044 //-------------------inherited methods from AbstractEventProducer------------------ 00045 // 00046 00050 protected void notifyOneListener(ProActiveListener proActiveListener, 00051 ProActiveEvent event) { 00052 NodeCreationEvent creationEvent = (NodeCreationEvent) event; 00053 NodeCreationEventListener creationEventListener = (NodeCreationEventListener) proActiveListener; 00054 00055 //notify the listener that a creation occurs 00056 creationEventListener.nodeCreated(creationEvent); 00057 } 00058 00059 // 00060 //-------------------PROTECTED METHODS------------------ 00061 // 00062 protected void notifyListeners(VirtualNode vn, int type, Node node, 00063 int nodeCreated) { 00064 if (hasListeners()) { 00065 notifyAllListeners(new NodeCreationEvent(vn, type, node, nodeCreated)); 00066 } else { 00067 if (logger.isDebugEnabled()) { 00068 logger.debug("no listener"); 00069 } 00070 } 00071 } 00072 00073 // 00074 //-------------------implements NodeCreationEventProducer------------------ 00075 // 00076 00080 public void addNodeCreationEventListener(NodeCreationEventListener listener) { 00081 addListener(listener); 00082 } 00083 00087 public void removeNodeCreationEventListener( 00088 NodeCreationEventListener listener) { 00089 } 00090 }
 1.5.1
 1.5.1
