00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.util; 00032 00033 import java.io.Serializable; 00034 00035 00040 public class MutableLong implements Serializable { 00041 private long value; 00042 00043 public MutableLong() { 00044 } 00045 00046 public MutableLong(long value) { 00047 this.value = value; 00048 } 00049 00050 public long getValue() { 00051 return this.value; 00052 } 00053 00054 public void setValue(long value) { 00055 this.value = value; 00056 } 00057 00058 public long add(long toAdd) { 00059 this.value += toAdd; 00060 return this.value; 00061 } 00062 00063 public boolean isLessThan(MutableLong l) { 00064 return this.value < l.getValue(); 00065 } 00066 00067 public int hashCode() { 00068 return (int) this.value; 00069 } 00070 00071 public boolean equals(Object mi) { 00072 if (mi instanceof MutableLong) { 00073 return this.value == ((MutableLong) mi).getValue(); 00074 } else { 00075 return false; 00076 } 00077 } 00078 }
1.5.1
