00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.collectiveitfs;
00032
00033 import java.io.Serializable;
00034 import java.lang.annotation.Annotation;
00035 import java.lang.reflect.Method;
00036 import java.lang.reflect.ParameterizedType;
00037 import java.lang.reflect.Type;
00038
00039 import org.objectweb.fractal.api.Interface;
00040 import org.objectweb.proactive.core.component.exceptions.ParameterDispatchException;
00041 import org.objectweb.proactive.core.component.type.annotations.multicast.ClassDispatchMetadata;
00042 import org.objectweb.proactive.core.component.type.annotations.multicast.MethodDispatchMetadata;
00043 import org.objectweb.proactive.core.component.type.annotations.multicast.ParamDispatch;
00044 import org.objectweb.proactive.core.component.type.annotations.multicast.ParamDispatchMetadata;
00045 import org.objectweb.proactive.core.component.type.annotations.multicast.ParamDispatchMode;
00046
00058 public class MulticastBindingChecker implements Serializable {
00059
00071     public static Method searchMatchingMethod(Method clientSideMethod, Method[] serverSideMethods, boolean serverItfIsGathercast, Interface serverSideItf) throws ParameterDispatchException, NoSuchMethodException {
00072         Method result = null;
00073         Type clientSideReturnType = clientSideMethod.getGenericReturnType();
00074         Type[] clientSideParametersTypes = clientSideMethod.getGenericParameterTypes();
00075         Class[] clientSideExceptionTypes = clientSideMethod.getExceptionTypes();
00076         ParamDispatch[] paramDispatchModes = getDispatchModes(clientSideMethod);
00077
00078
00079         serverSideMethodsLoop:
00080         for (Method serverSideMethod : serverSideMethods) {
00081                 if (serverItfIsGathercast) {
00082
00083                         Type[] genericParamTypes = serverSideMethod.getGenericParameterTypes();
00084                         Class[] correspondingParamTypes = new Class[genericParamTypes.length];
00085                         for (int i = 0; i < genericParamTypes.length; i++) {
00086                                         ParameterizedType t = (ParameterizedType)genericParamTypes[i];
00087                                         correspondingParamTypes[i] = (Class)t.getActualTypeArguments()[0];
00088                                 }
00089                         serverSideMethod = serverSideItf.getClass().getMethod(serverSideMethod.getName(), correspondingParamTypes);
00090                 }
00091
00092             if (! serverSideMethod.getName().equals(clientSideMethod.getName())) {
00093                 continue serverSideMethodsLoop;
00094             }
00095
00096
00097             if (!(clientSideReturnType == Void.TYPE)) {
00098                 Type cType = ((ParameterizedType) clientSideMethod.getGenericReturnType()).getActualTypeArguments()[0];
00099                 Class clientSideReturnTypeArgument = null;
00100                 if (cType instanceof ParameterizedType) {
00101                         clientSideReturnTypeArgument = (Class)((ParameterizedType)cType).getRawType();
00102                 } else {
00103                         clientSideReturnTypeArgument = (Class) cType;
00104                 }
00105                 if (!(clientSideReturnTypeArgument.isAssignableFrom(
00106                             serverSideMethod.getReturnType()))) {
00107                     continue serverSideMethodsLoop;
00108                 }
00109             } else {
00110                 if (!(serverSideMethod.getReturnType() == Void.TYPE)) {
00111                     continue serverSideMethodsLoop;
00112                 }
00113             }
00114
00115
00116             Type[] serverSideParametersTypes = serverSideMethod.getGenericParameterTypes();
00117
00118             for (int i=0; i<serverSideMethod.getGenericParameterTypes().length; i++) {
00119                     if (!(paramDispatchModes[i].match(clientSideParametersTypes[i], serverSideParametersTypes[i]))) {
00120                         continue serverSideMethodsLoop;
00121                     }
00122             }
00123
00124
00125             Class[] serverSideExceptionTypes = serverSideMethod.getExceptionTypes();
00126             for (Class clientExceptionType : clientSideExceptionTypes) {
00127                 boolean match = false;
00128                 for (Class serverExceptionType : serverSideExceptionTypes) {
00129                     if (clientExceptionType.isAssignableFrom(serverExceptionType)) {
00130                         match = true;
00131                         break;
00132                     }
00133                 }
00134                 if (!match) {
00135                     throw new NoSuchMethodException("found a matching method in server interface for " + clientSideMethod.toGenericString() + " but the types of thrown exceptions do not match");
00136                 }
00137             }
00138
00139             if (result != null) {
00140                 throw new NoSuchMethodException("cannot find matching method for " + clientSideMethod.toGenericString() + " because there are several matches in the server interface ");
00141             } else {
00142                 result = serverSideMethod;
00143             }
00144
00145         }
00146
00147         if (result == null) {
00148             throw new NoSuchMethodException("cannot find matching method for " + clientSideMethod.toGenericString());
00149         }
00150
00151         return result;
00152     }
00153
00160     public static ParamDispatch getParamDispatchMode(ParamDispatchMetadata a)
00161         throws ParameterDispatchException {
00162         ParamDispatch mode = null;
00163         if (a == null) {
00164             return ParamDispatchMode.BROADCAST;
00165         }
00166
00167         mode = a.mode();
00168
00169         if (mode.equals(ParamDispatchMode.CUSTOM)) {
00170             try {
00171                 mode = (ParamDispatch) ((ParamDispatchMetadata) a).customMode().newInstance();
00172             } catch (InstantiationException e) {
00173                 throw new ParameterDispatchException(
00174                     "custom annotation refers to a class containing the dispatch algorithm, but this class that cannot be instantiated : " +
00175                     ((ParamDispatchMetadata) a).customMode(),
00176                     e);
00177             } catch (IllegalAccessException e) {
00178                 throw new ParameterDispatchException(
00179                     "custom annotation refers to a class containing the dispatch algorithm, but this class that cannot be instantiated : " +
00180                     ((ParamDispatchMetadata) a).customMode(),
00181                     e);
00182             }
00183         }
00184
00185         return mode;
00186     }
00187
00194     public static ParamDispatch[] getDispatchModes(Method matchingMethodInClientInterface) throws ParameterDispatchException {
00195         ParamDispatch[] result = new ParamDispatch[matchingMethodInClientInterface.getParameterTypes().length];
00196
00197         Annotation[] classAnnotations = matchingMethodInClientInterface.getDeclaringClass()
00198        .getAnnotations();
00199         Annotation[] methodAnnotations = matchingMethodInClientInterface.getAnnotations();
00200         Annotation[][] paramsAnnotations = matchingMethodInClientInterface.getParameterAnnotations();
00201
00202
00203         for (Annotation annotation : classAnnotations) {
00204             if (ClassDispatchMetadata.class.isAssignableFrom(annotation.annotationType())) {
00205                 for (int i = 0; i < matchingMethodInClientInterface.getParameterTypes().length;
00206                      i++) {
00207                     result[i] = getParamDispatchMode(((ClassDispatchMetadata) annotation).mode());
00208                     if (result[i] == null) {
00209                         result[i] = ParamDispatchMode.BROADCAST;
00210                     }
00211                 }
00212                 return result;
00213             }
00214         }
00215
00216
00217         for (Annotation annotation : methodAnnotations) {
00218             if (MethodDispatchMetadata.class.isAssignableFrom(annotation.annotationType())) {
00219                 for (int i = 0; i < matchingMethodInClientInterface.getParameterTypes().length;
00220                      i++) {
00221                     result[i] = getParamDispatchMode(((MethodDispatchMetadata) annotation).mode());
00222                     if (result[i] == null) {
00223                         result[i] = ParamDispatchMode.BROADCAST;
00224                     }
00225                 }
00226                 return result;
00227             }
00228         }
00229
00230
00231         for (int i = 0; i < matchingMethodInClientInterface.getParameterTypes().length; i++) {
00232             Annotation[] currentParamAnnotations = paramsAnnotations[i];
00233             for (int j = 0; j < currentParamAnnotations.length; j++) {
00234                 if ((currentParamAnnotations[j] != null) &&
00235                         ParamDispatchMetadata.class.isAssignableFrom(
00236                             currentParamAnnotations[j].annotationType())) {
00237                         result[i] = getParamDispatchMode((ParamDispatchMetadata) currentParamAnnotations[j]);
00238                         if (result[i] == null) {
00239                             result[i] = ParamDispatchMode.BROADCAST;
00240                         }
00241                 }
00242             }
00243             if (result[i] == null) {
00244                     result[i] = ParamDispatchMode.BROADCAST;
00245             }
00246
00247         }
00248
00249         return result;
00250     }
00251 }
