org/objectweb/proactive/scheduler/policy/MixedPolicy.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.scheduler.policy;
00032
00033 import java.util.Vector;
00034
00035 import org.objectweb.proactive.scheduler.GenericJob;
00036 import org.objectweb.proactive.scheduler.RessourceManager;
00037
00038
00045 public class MixedPolicy extends AbstractPolicy {
00046     private Vector policies;
00047
00048     public MixedPolicy() {
00049         // TODO Auto-generated constructor stub
00050     }
00051
00059     public MixedPolicy(RessourceManager ressourceManager, Vector policyNames) {
00060         super(ressourceManager);
00061         this.policies = new Vector();
00062         for (int i = 0; i < policyNames.size(); ++i) {
00063             String policyName = (String) policyNames.get(i);
00064             try {
00065                 policies.add(Class.forName(policyName).newInstance());
00066             } catch (Exception e) {
00067                 // TODO Auto-generated catch block
00068                 e.printStackTrace();
00069             }
00070         }
00071     }
00072
00079     public boolean isToBeServed(GenericJob job1, GenericJob job2) {
00080         // TODO Auto-generated method stub
00081         for (int i = 0; i < this.policies.size(); ++i) {
00082             AbstractPolicy policy = (AbstractPolicy) this.policies.get(i);
00083             if (policy.isToBeServed(job2, job1)) {
00084                 return false;
00085             }
00086         }
00087
00088         return true;
00089     }
00090 }
Generated on Mon Jan 22 15:16:12 2007 for ProActive by  doxygen 1.5.1
