org/objectweb/proactive/core/mop/MethodCallExceptionContext.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.mop;
00032
00033 import java.io.Serializable;
00034
00035
00036 /* This class is optimized so that its instances are immutable */
00037 public class MethodCallExceptionContext implements Serializable {
00038
00043     private boolean runtimeExceptionHandled;
00044
00049     private boolean exceptionAsynchronously;
00050
00054     public static final MethodCallExceptionContext DEFAULT = new MethodCallExceptionContext(false,
00055             false);
00056
00061     public MethodCallExceptionContext(boolean runtimeExceptionHandled,
00062         boolean exceptionAsynchronously) {
00063         this.runtimeExceptionHandled = runtimeExceptionHandled;
00064         this.exceptionAsynchronously = exceptionAsynchronously;
00065     }
00066
00070     public boolean isExceptionAsynchronously() {
00071         return exceptionAsynchronously;
00072     }
00073
00077     public boolean isRuntimeExceptionHandled() {
00078         return runtimeExceptionHandled;
00079     }
00080
00081     public static MethodCallExceptionContext optimize(MethodCallExceptionContext context) {
00082         if (DEFAULT.equals(context)) {
00083             context = null;
00084         }
00085
00086         return context;
00087     }
00088
00089     public String toString() {
00090         return "[rt:" + runtimeExceptionHandled + ", async:" +
00091         exceptionAsynchronously + "]";
00092     }
00093 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
