org/objectweb/proactive/core/group/MethodCallControlForGroup.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.group;
00032
00033 import java.io.IOException;
00034 import java.lang.reflect.InvocationTargetException;
00035 import java.lang.reflect.Method;
00036 import java.util.LinkedList;
00037
00038 import org.objectweb.proactive.core.mop.MethodCall;
00039 import org.objectweb.proactive.core.mop.MethodCallExecutionFailedException;
00040
00041
00045 public abstract class MethodCallControlForGroup extends MethodCall {
00046     public MethodCallControlForGroup() {
00047     }
00048
00049     public Method getReifiedMethod() {
00050         return null;
00051     }
00052
00058     public int getNumberOfParameter() {
00059         return 0;
00060     }
00061
00062     //
00063     // --- PRIVATE METHODS FOR SERIALIZATION --------------------------------------------------------------
00064     //
00065     private void writeObject(java.io.ObjectOutputStream out)
00066         throws java.io.IOException {
00067         this.writeTheObject(out);
00068     }
00069
00070     protected void writeTheObject(java.io.ObjectOutputStream out)
00071         throws java.io.IOException {
00072         out.defaultWriteObject();
00073     }
00074
00075     private void readObject(java.io.ObjectInputStream in)
00076         throws IOException, ClassNotFoundException {
00077         this.readTheObject(in);
00078     }
00079
00080     protected void readTheObject(java.io.ObjectInputStream in)
00081         throws IOException, ClassNotFoundException {
00082         in.defaultReadObject();
00083     }
00084
00085     // Overloaded to avoid this MethodCallControlForGroup object
00086     // go inside the recycling pool of MethodCall.
00087     protected void finalize() {
00088     }
00089
00090     // return null
00091     public Object execute(Object targetObject)
00092         throws InvocationTargetException, MethodCallExecutionFailedException {
00093         return null;
00094     }
00095
00101     public boolean isAsynchronousWayCall() {
00102         return false;
00103     }
00104
00110     public boolean isOneWayCall() {
00111         return true;
00112     }
00113
00118     public void setBarrierTags(LinkedList barrierTags) {
00119     }
00120
00125     public LinkedList getBarrierTags() {
00126         return null;
00127     }
00128 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
