org/objectweb/proactive/core/group/spmd/MethodBarrier.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.group.spmd;
00032
00033 import java.io.Serializable;
00034
00035
00041 public class MethodBarrier implements Serializable {
00042     private String[] methodNames;
00043     private boolean[] arrivedMethods;
00044
00049     public MethodBarrier(String[] methodNames) {
00050         this.methodNames = methodNames;
00051         this.arrivedMethods = new boolean[this.methodNames.length];
00052         for (int i = 0; i < this.arrivedMethods.length; i++) {
00053             this.arrivedMethods[i] = false;
00054         }
00055     }
00056
00061     public boolean barrierOver() {
00062         boolean result = true;
00063         for (int i = 0; ((i < this.arrivedMethods.length) && (result)); i++) {
00064             result &= this.arrivedMethods[i];
00065         }
00066         return result;
00067     }
00068
00076     public boolean checkMethod(String methodName) {
00077         int index = this.indexOf(methodName);
00078         if ((index < 0) || this.arrivedMethods[index]) {
00079             return false;
00080         } else {
00081             this.arrivedMethods[index] = true;
00082             return true;
00083         }
00084     }
00085
00092     private int indexOf(String methodName) {
00093         boolean find = false;
00094         int i;
00095         for (i = 0; ((i < this.methodNames.length) && (!find)); i++) {
00096             find = this.methodNames[i].equals(methodName) &&
00097                 !this.arrivedMethods[i];
00098         }
00099         if (find) {
00100             return i - 1;
00101         } else {
00102             return -1;
00103         }
00104     }
00105 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
