00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.gen;
00032
00033 import java.io.Serializable;
00034 import java.util.ArrayList;
00035 import java.util.HashMap;
00036 import java.util.Iterator;
00037 import java.util.List;
00038 import java.util.Map;
00039 import java.util.Vector;
00040
00041 import javassist.CannotCompileException;
00042 import javassist.CtClass;
00043 import javassist.CtField;
00044 import javassist.CtMethod;
00045 import javassist.CtNewMethod;
00046 import javassist.Modifier;
00047 import javassist.NotFoundException;
00048
00049 import org.objectweb.fractal.api.Component;
00050 import org.objectweb.fractal.api.type.InterfaceType;
00051 import org.objectweb.proactive.core.component.ProActiveInterface;
00052 import org.objectweb.proactive.core.component.ProActiveInterfaceImpl;
00053 import org.objectweb.proactive.core.component.exceptions.InterfaceGenerationFailedException;
00054 import org.objectweb.proactive.core.component.type.ProActiveInterfaceType;
00055 import org.objectweb.proactive.core.mop.JavassistByteCodeStubBuilder;
00056 import org.objectweb.proactive.core.mop.StubObject;
00057 import org.objectweb.proactive.core.util.ClassDataCache;
00058 import org.objectweb.proactive.core.util.log.Loggers;
00059 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00060
00061
00078 public class MetaObjectInterfaceClassGenerator
00079 extends AbstractInterfaceClassGenerator {
00080 protected static final String IMPL_FIELD_NAME = "impl";
00081 private static MetaObjectInterfaceClassGenerator instance;
00082
00083
00084 protected boolean isPrimitive = false;
00085
00086 public MetaObjectInterfaceClassGenerator() {
00087 }
00088
00089 public static MetaObjectInterfaceClassGenerator instance() {
00090 if (instance == null) {
00091 return new MetaObjectInterfaceClassGenerator();
00092 } else {
00093 return instance;
00094 }
00095 }
00096
00097 public ProActiveInterface generateInterface(final String interfaceName,
00098 Component owner, ProActiveInterfaceType interfaceType, boolean isInternal,
00099 boolean isFunctionalInterface)
00100 throws InterfaceGenerationFailedException {
00101 try {
00102 if (ProActiveLogger.getLogger(
00103 Loggers.COMPONENTS_GEN_ITFS).isDebugEnabled()) {
00104 ProActiveLogger.getLogger(Loggers.COMPONENTS_GEN_ITFS)
00105 .debug("generating metaobject interface reference");
00106 }
00107
00108 String generatedClassFullName = org.objectweb.proactive.core.component.gen.Utils.getMetaObjectClassName(interfaceName,
00109 interfaceType.getFcItfSignature());
00110
00111 Class generated_class;
00112
00113
00114 try {
00115 generated_class = loadClass(generatedClassFullName);
00116 } catch (ClassNotFoundException cnfe) {
00117 CtMethod[] reifiedMethods;
00118 CtClass generatedCtClass = pool.makeClass(generatedClassFullName);
00119
00120
00121
00122
00123 List interfacesToImplement = new ArrayList();
00124
00125
00126 CtClass functional_itf = pool.get(interfaceType.getFcItfSignature());
00127 generatedCtClass.addInterface(functional_itf);
00128
00129 interfacesToImplement.add(functional_itf);
00130
00131
00132 interfacesToImplement.add(pool.get(Serializable.class.getName()));
00133 generatedCtClass.addInterface(pool.get(
00134 Serializable.class.getName()));
00135
00136
00137 generatedCtClass.addInterface(pool.get(
00138 StubObject.class.getName()));
00139
00140
00141 List interfacesToImplementAndSuperInterfaces = new ArrayList(interfacesToImplement);
00142 addSuperInterfaces(interfacesToImplementAndSuperInterfaces);
00143 generatedCtClass.setSuperclass(pool.get(
00144 ProActiveInterfaceImpl.class.getName()));
00145 JavassistByteCodeStubBuilder.createStubObjectMethods(generatedCtClass);
00146
00147 CtField implField = new CtField(pool.get(Object.class.getName()),
00148 IMPL_FIELD_NAME, generatedCtClass);
00149 generatedCtClass.addField(implField);
00150 CtMethod implGetter = CtNewMethod.getter("getFcItfImpl",
00151 implField);
00152 generatedCtClass.addMethod(implGetter);
00153 CtMethod implSetter = CtNewMethod.setter("setFcItfImpl",
00154 implField);
00155 generatedCtClass.addMethod(implSetter);
00156
00157
00158 CtField methodsField = new CtField(pool.get(
00159 "java.lang.reflect.Method[]"), "overridenMethods",
00160 generatedCtClass);
00161 methodsField.setModifiers(Modifier.STATIC);
00162 generatedCtClass.addField(methodsField);
00163
00164
00165 CtField genericTypesMappingField = new CtField(pool.get(
00166 "java.util.Map"), "genericTypesMapping",
00167 generatedCtClass);
00168
00169 genericTypesMappingField.setModifiers(Modifier.STATIC);
00170 generatedCtClass.addField(genericTypesMappingField);
00171
00172
00173
00174 Map methodsToImplement = new HashMap();
00175 List classesIndexer = new Vector();
00176
00177 CtClass[] params;
00178 CtClass itf;
00179
00180
00181 Iterator it = interfacesToImplementAndSuperInterfaces.iterator();
00182 while (it.hasNext()) {
00183 itf = (CtClass) it.next();
00184 if (!classesIndexer.contains(itf.getName())) {
00185 classesIndexer.add(itf.getName());
00186 }
00187
00188 CtMethod[] declaredMethods = itf.getDeclaredMethods();
00189
00190 for (int i = 0; i < declaredMethods.length; i++) {
00191 CtMethod currentMethod = declaredMethods[i];
00192
00193
00194
00195 String key = "";
00196 key = key + currentMethod.getName();
00197 params = currentMethod.getParameterTypes();
00198 for (int k = 0; k < params.length; k++) {
00199 key = key + params[k].getName();
00200 }
00201
00202
00203 methodsToImplement.put(key, currentMethod);
00204 }
00205 }
00206
00207 reifiedMethods = (CtMethod[]) (methodsToImplement.values()
00208 .toArray(new CtMethod[methodsToImplement.size()]));
00209
00210
00211
00212
00213 Vector v = new Vector();
00214 int initialNumberOfMethods = reifiedMethods.length;
00215
00216 for (int i = 0; i < initialNumberOfMethods; i++) {
00217 if (JavassistByteCodeStubBuilder.checkMethod(
00218 reifiedMethods[i])) {
00219 v.addElement(reifiedMethods[i]);
00220 }
00221 }
00222 CtMethod[] validMethods = new CtMethod[v.size()];
00223 v.copyInto(validMethods);
00224
00225 reifiedMethods = validMethods;
00226
00227 JavassistByteCodeStubBuilder.createStaticInitializer(generatedCtClass,
00228 reifiedMethods, classesIndexer, interfaceType.getFcItfSignature(), null);
00229
00230 createMethods(generatedCtClass, reifiedMethods, interfaceType);
00231
00232
00233
00234
00235 byte[] bytecode = generatedCtClass.toBytecode();
00236 ClassDataCache.instance().addClassData(generatedClassFullName,
00237 generatedCtClass.toBytecode());
00238 if (logger.isDebugEnabled()) {
00239 logger.debug("added " + generatedClassFullName +
00240 " to cache");
00241 }
00242 if (logger.isDebugEnabled()) {
00243 logger.debug("generated classes cache is : " +
00244 ClassDataCache.instance().toString());
00245 }
00246
00247
00248 generated_class = Utils.defineClass(generatedClassFullName, bytecode);
00249 }
00250
00251 ProActiveInterfaceImpl reference = (ProActiveInterfaceImpl) generated_class.newInstance();
00252 reference.setFcItfName(interfaceName);
00253 reference.setFcItfOwner(owner);
00254 reference.setFcType(interfaceType);
00255 reference.setFcIsInternal(isInternal);
00256
00257 return reference;
00258 } catch (Exception e) {
00259 throw new InterfaceGenerationFailedException(
00260 "Cannot generate meta object representative on interface [" + interfaceName + "] with signature [" + interfaceType.getFcItfSignature() + "] with javassist",
00261 e);
00262 }
00263 }
00264
00265 private void createMethods(CtClass generatedCtClass,
00266 CtMethod[] reifiedMethods, InterfaceType interfaceType)
00267 throws CannotCompileException, NotFoundException {
00268 for (int i = 0; i < reifiedMethods.length; i++) {
00269 CtClass[] paramTypes = reifiedMethods[i].getParameterTypes();
00270
00271 String body = "return ";
00272 body += ("((" + interfaceType.getFcItfSignature() + ")");
00273 body += (IMPL_FIELD_NAME + ")." + reifiedMethods[i].getName() +
00274 "(");
00275 for (int j = 0; j < paramTypes.length; j++) {
00276 body += ("(" + paramTypes[j].getName() + ")" + ("$" + (j + 1)));
00277 if (j < (paramTypes.length - 1)) {
00278 body += ",";
00279 }
00280 }
00281 body += ")";
00282
00283 body += ";";
00284 body += "\n}";
00285
00286
00287 CtMethod methodToGenerate = CtNewMethod.make(reifiedMethods[i].getReturnType(),
00288 reifiedMethods[i].getName(),
00289 reifiedMethods[i].getParameterTypes(),
00290 reifiedMethods[i].getExceptionTypes(), body,
00291 generatedCtClass);
00292 generatedCtClass.addMethod(methodToGenerate);
00293 }
00294 }
00295 }
