00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.body.ft.protocols.cic.infos; 00032 00033 import java.util.Hashtable; 00034 00035 import org.objectweb.proactive.core.body.ft.message.MessageInfo; 00036 import org.objectweb.proactive.core.body.ft.protocols.FTManagerFactory; 00037 00038 00043 public class MessageInfoCIC implements MessageInfo { 00044 // checkpointing protocol 00045 public char checkpointIndex; 00046 public char historyIndex; 00047 public char incarnation; 00048 public char lastRecovery; 00049 public char isOrphanFor; 00050 public boolean fromHalfBody; 00051 00052 // output commit protocol 00053 public long positionInHistory; 00054 public Hashtable vectorClock; 00055 00059 public int getProtocolType() { 00060 return FTManagerFactory.PROTO_CIC; 00061 } 00062 00066 public boolean isFromHalfBody() { 00067 return this.fromHalfBody; 00068 } 00069 }
1.5.1
