00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.event; 00032 00033 import org.objectweb.proactive.core.UniqueID; 00034 import org.objectweb.proactive.core.body.ft.message.MessageInfo; 00035 import org.objectweb.proactive.core.body.ft.protocols.FTManager; 00036 import org.objectweb.proactive.core.body.message.Message; 00037 00038 00051 public class MessageEvent extends ProActiveEvent implements Message, 00052 java.io.Serializable { 00053 00055 public static final int REQUEST_SENT = 10; 00056 00058 public static final int REQUEST_RECEIVED = 20; 00059 00061 public static final int REPLY_SENT = 30; 00062 00064 public static final int REPLY_RECEIVED = 40; 00065 00067 public static final int VOID_REQUEST_SERVED = 50; 00068 00070 public static final int SERVING_STARTED = 60; 00071 protected UniqueID destinationID; 00072 00075 protected int requestQueueLength; 00076 00087 public MessageEvent(Message message, int messageActionType, 00088 UniqueID destinationID, int requestQueueLength) { 00089 super(message, messageActionType); 00090 this.destinationID = destinationID; 00091 this.requestQueueLength = requestQueueLength; 00092 } 00093 00094 // 00095 // -- PUBLIC METHODS ----------------------------------------------- 00096 // 00097 00104 public UniqueID getDestinationBodyID() { 00105 return destinationID; 00106 } 00107 00112 public int getRequestQueueLength() { 00113 return requestQueueLength; 00114 } 00115 00120 public String toString() { 00121 return "methodName=" + getMethodName() + " sourceID=" + 00122 getSourceBodyID() + " destinationID=" + getDestinationBodyID() + 00123 " sequenceNumber=" + getSequenceNumber(); 00124 } 00125 00126 public boolean wasSent() { 00127 return (type == REQUEST_SENT) || (type == REPLY_SENT); 00128 } 00129 00130 // 00131 // -- implements Message ----------------------------------------------- 00132 // 00133 public UniqueID getSourceBodyID() { 00134 return getMessage().getSourceBodyID(); 00135 } 00136 00137 public String getMethodName() { 00138 return getMessage().getMethodName(); 00139 } 00140 00141 public long getSequenceNumber() { 00142 return getMessage().getSequenceNumber(); 00143 } 00144 00145 public boolean isOneWay() { 00146 return getMessage().isOneWay(); 00147 } 00148 00149 public MessageInfo getMessageInfo() { 00150 return getMessage().getMessageInfo(); 00151 } 00152 00153 public void setMessageInfo(MessageInfo mi) { 00154 getMessage().setMessageInfo(mi); 00155 } 00156 00157 public void setIgnoreIt(boolean ignore) { 00158 getMessage().setIgnoreIt(ignore); 00159 } 00160 00161 public boolean ignoreIt() { 00162 return getMessage().ignoreIt(); 00163 } 00164 00165 public void setFTManager(FTManager ft) { 00166 getMessage().setFTManager(ft); 00167 } 00168 00169 public FTManager getFTManager() { 00170 return getMessage().getFTManager(); 00171 } 00172 00173 // 00174 // -- PRIVATE METHODS ----------------------------------------------- 00175 // 00176 private final Message getMessage() { 00177 return (Message) getSource(); 00178 } 00179 }
1.5.1
