00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.config.xml;
00032
00033 import java.io.IOException;
00034
00035 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00036 import org.objectweb.proactive.core.xml.handler.AbstractUnmarshallerDecorator;
00037 import org.objectweb.proactive.core.xml.handler.UnmarshallerHandler;
00038 import org.objectweb.proactive.core.xml.io.Attributes;
00039 import org.xml.sax.InputSource;
00040 import org.xml.sax.SAXException;
00041
00042
00043 public class MasterFileHandler extends AbstractUnmarshallerDecorator
00044 implements MasterFileConstants {
00045
00046
00047
00048 protected static ProActiveConfiguration config;
00049
00050 public MasterFileHandler() {
00051 addHandler(PROPERTIES_TAG,
00052 new PropertiesHandler(MasterFileHandler.config));
00053
00054
00055 }
00056
00061 public static void createMasterFileHandler(String filename,
00062 ProActiveConfiguration config) {
00063 MasterFileHandler.config = config;
00064
00065 InitialHandler h = new InitialHandler();
00066 org.objectweb.proactive.core.xml.io.StreamReader sr;
00067
00068 try {
00069 InputSource source = null;
00070
00071
00072 if (filename.startsWith("bundle://")) {
00073
00074
00075 filename = "/ProActiveConfiguration.xml";
00076
00077 source = new InputSource(MasterFileHandler.class.getResourceAsStream(
00078 filename));
00079 } else {
00080 source = new org.xml.sax.InputSource(filename);
00081 }
00082 sr = new org.objectweb.proactive.core.xml.io.StreamReader(source, h);
00083 sr.read();
00084 } catch (IOException e) {
00085 e.printStackTrace();
00086 } catch (SAXException e) {
00087 e.printStackTrace();
00088 }
00089 }
00090
00091 protected void notifyEndActiveHandler(String name,
00092 UnmarshallerHandler activeHandler) throws SAXException {
00093
00094 }
00095
00096 public Object getResultObject() throws SAXException {
00097
00098 return null;
00099 }
00100
00101 public void startContextElement(String name, Attributes attributes)
00102 throws SAXException {
00103 }
00104
00105
00106
00107
00108 private static class InitialHandler extends AbstractUnmarshallerDecorator {
00109 private MasterFileHandler masterFileHandler;
00110
00111
00112 private InitialHandler() {
00113 super();
00114 masterFileHandler = new MasterFileHandler();
00115
00116
00117 this.addHandler(MASTER_TAG, masterFileHandler);
00118 }
00119
00120 public Object getResultObject() throws org.xml.sax.SAXException {
00121
00122 return null;
00123 }
00124
00125 public void startContextElement(String name, Attributes attributes)
00126 throws org.xml.sax.SAXException {
00127 }
00128
00129 protected void notifyEndActiveHandler(String name,
00130 UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00131 }
00132 }
00133
00134
00135
00136
00137
00138
00139
00140
00141
00142
00143
00144
00145
00146
00147
00148
00149
00150
00151
00152
00153
00154
00155
00156
00157
00158
00159
00160
00161
00162
00163
00164
00165 }
