org/objectweb/proactive/calcium/skeletons/Map.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.calcium.skeletons;
00032
00033 import org.objectweb.proactive.calcium.Task;
00034 import org.objectweb.proactive.calcium.exceptions.EnvironmentException;
00035 import org.objectweb.proactive.calcium.interfaces.Conquer;
00036 import org.objectweb.proactive.calcium.interfaces.Divide;
00037 import org.objectweb.proactive.calcium.interfaces.Skeleton;
00038
00050 public class Map<T> extends DaC<T> {
00051
00052         public Map(Divide<T> div, Skeleton<T> child, Conquer<T> conq){
00053
00054                 super(div, null,child,conq);
00055         }
00056
00057         //Override parent method to avoid using the condition
00058         public Task<T> compute(Task<T> t) throws EnvironmentException {
00059
00060                 //Split the task if not already splitted
00061                 if(!t.hasFinishedChild()){
00062                         return divide(t);
00063                 }
00064
00065                 //else conquer the subtask
00066                 return conquer(t);
00067         }
00068
00069 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
