00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.descriptor.xml;
00032
00033 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00034 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00035 import org.objectweb.proactive.core.xml.handler.BasicUnmarshaller;
00036 import org.objectweb.proactive.core.xml.handler.CollectionUnmarshaller;
00037 import org.objectweb.proactive.core.xml.handler.PassiveCompositeUnmarshaller;
00038 import org.objectweb.proactive.core.xml.handler.UnmarshallerHandler;
00039 import org.objectweb.proactive.core.xml.io.Attributes;
00040 import org.objectweb.proactive.scheduler.GenericJob;
00041 import org.objectweb.proactive.scheduler.Scheduler;
00042 import org.objectweb.proactive.scheduler.SchedulerConstants;
00043
00044
00052 class MainDefinitionHandler extends PassiveCompositeUnmarshaller
00053 implements ProActiveDescriptorConstants, SchedulerConstants {
00054 private ProActiveDescriptor proActiveDescriptor;
00055 private Scheduler scheduler;
00056 private String jobId;
00057
00058
00059
00060
00061
00062
00063
00064 public MainDefinitionHandler() {
00065 }
00066
00067 public MainDefinitionHandler(ProActiveDescriptor proActiveDescriptor) {
00068 super();
00069 this.proActiveDescriptor = proActiveDescriptor;
00070 this.addHandler(ARG_TAG, new ArgHandler(proActiveDescriptor));
00071 this.addHandler(MAP_TO_VIRTUAL_NODE_TAG,
00072 new MapToVirtualNodeHandler(proActiveDescriptor));
00073 }
00074
00075 public MainDefinitionHandler(Scheduler scheduler, String jobId,
00076 ProActiveDescriptor proActiveDescriptor) {
00077 this.proActiveDescriptor = proActiveDescriptor;
00078 UnmarshallerHandler pathHandler = new PathHandler();
00079 CollectionUnmarshaller classPath_Handler = new CollectionUnmarshaller(String.class);
00080 classPath_Handler.addHandler(ABS_PATH_TAG, pathHandler);
00081 this.scheduler = scheduler;
00082 this.jobId = jobId;
00083 this.addHandler(ARG_TAG, new ArgHandler(proActiveDescriptor));
00084 this.addHandler(MAP_TO_VIRTUAL_NODE_TAG,
00085 new MapToVirtualNodeHandler(proActiveDescriptor));
00086 this.addHandler(CLASSPATH_TAG, classPath_Handler);
00087 }
00088
00089 public void startContextElement(String name, Attributes attributes)
00090 throws org.xml.sax.SAXException {
00091 String id = attributes.getValue("id");
00092 String className = attributes.getValue("class");
00093
00094 if (!checkNonEmpty(className)) {
00095 throw new org.xml.sax.SAXException(
00096 "class Tag without any mainDefinition defined");
00097 }
00098
00099 if (scheduler != null) {
00100 GenericJob tmpJob = scheduler.getTmpJob(this.jobId);
00101 tmpJob.setClassName(className);
00102 }
00103
00104 proActiveDescriptor.createMainDefinition(id);
00105
00106 proActiveDescriptor.setMainDefined(true);
00107 proActiveDescriptor.mainDefinitionSetMainClass(className);
00108 }
00109
00110 protected void notifyEndActiveHandler(String name,
00111 UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00112 if (name.equals(ARG_TAG)) {
00113
00114 }
00115
00116 if (name.equals(MAP_TO_VIRTUAL_NODE_TAG)) {
00117
00118 }
00119
00120 if (name.equals(CLASSPATH_TAG)) {
00121
00122 if (scheduler != null) {
00123 String[] result = (String[]) activeHandler.getResultObject();
00124 GenericJob job = scheduler.getTmpJob(this.jobId);
00125 job.setClassPath(result);
00126
00127
00128
00129 }
00130 }
00131 }
00132
00133
00134
00135
00136
00137
00138
00139
00140
00141
00142
00143
00144
00145 private class ArgHandler extends BasicUnmarshaller {
00146 ProActiveDescriptor proActiveDescriptor;
00147
00148 private ArgHandler(ProActiveDescriptor proActiveDescriptor) {
00149 this.proActiveDescriptor = proActiveDescriptor;
00150 }
00151
00152 public void startContextElement(String name, Attributes attributes)
00153 throws org.xml.sax.SAXException {
00154 String arg = attributes.getValue("value");
00155
00156
00157 if (!checkNonEmpty(arg)) {
00158 throw new org.xml.sax.SAXException(
00159 "value Tag without any arg defined");
00160 }
00161
00162 if (scheduler != null) {
00163 GenericJob job = scheduler.getTmpJob(jobId);
00164 job.addMainParameter(arg);
00165 }
00166
00167 proActiveDescriptor.mainDefinitionAddParameter(arg);
00168 }
00169 }
00170
00171 private class MapToVirtualNodeHandler extends BasicUnmarshaller {
00172 ProActiveDescriptor proActiveDescriptor;
00173
00174 private MapToVirtualNodeHandler(ProActiveDescriptor proActiveDescriptor) {
00175 this.proActiveDescriptor = proActiveDescriptor;
00176 }
00177
00178 public void startContextElement(String name, Attributes attributes)
00179 throws org.xml.sax.SAXException {
00180 String virtualNode = attributes.getValue("value");
00181
00182 if (!checkNonEmpty(virtualNode)) {
00183 throw new org.xml.sax.SAXException(
00184 "value Tag without any mapToVirtualNode defined");
00185 }
00186
00187 VirtualNode vn = (VirtualNode) proActiveDescriptor.createVirtualNode(virtualNode,
00188 false, true);
00189
00190 proActiveDescriptor.mainDefinitionAddVirtualNode(vn);
00191 }
00192 }
00193 }
