00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.mpi;
00032
00033 import org.apache.log4j.Logger;
00034
00035 import org.objectweb.proactive.ActiveObjectCreationException;
00036 import org.objectweb.proactive.ProActive;
00037 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00038 import org.objectweb.proactive.core.node.NodeException;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00042 import java.io.IOException;
00043
00044 import java.util.ArrayList;
00045 import java.util.Hashtable;
00046
00047
00048 public class MPISpmdProxy implements MPISpmd, java.io.Serializable {
00049     protected final static Logger MPI_PROXY_LOGGER = ProActiveLogger.getLogger(Loggers.MPI);
00050
00052     private String status = MPIConstants.MPI_DEFAULT_STATUS;
00053
00055     private String name;
00056
00058     private MPISpmdImpl target;
00059
00063     public MPISpmdProxy(VirtualNode vn) throws RuntimeException {
00064         try {
00065             target = (MPISpmdImpl) ProActive.newActive(MPISpmdImpl.class.getName(),
00066                     new Object[] { vn });
00067         } catch (ActiveObjectCreationException e) {
00068             e.printStackTrace();
00069         } catch (NodeException e) {
00070             e.printStackTrace();
00071         }
00072         name = target.getName();
00073         MPI_PROXY_LOGGER.debug("[MPI Proxy] creating MPI SPMD active object: " +
00074             name);
00075         MPI_PROXY_LOGGER.debug("[MPI Proxy] status : " + status);
00076
00077         try {
00078             ProActive.setImmediateService(target, "killMPI");
00079             ProActive.setImmediateService(target, "getStatus");
00080             ProActive.setImmediateService(target, "isFinished");
00081             ProActive.setImmediateService(target, "getSpmdClassesParams");
00082             ProActive.setImmediateService(target, "getSpmdClasses");
00083             ProActive.setImmediateService(target, "getClassesParams");
00084             ProActive.setImmediateService(target, "getClasses");
00085         } catch (IOException e) {
00086             e.printStackTrace();
00087         }
00088     }
00089
00094     public MPIResult startMPI() throws IllegalMPIStateException {
00095         MPI_PROXY_LOGGER.debug(
00096             "[MPI Proxy] call start method on active object ");
00097         MPI_PROXY_LOGGER.debug("[MPI Proxy] status : " + status);
00098
00099         if (status.equals(MPIConstants.MPI_UNSTARTED)) {
00100             setStatus(MPIConstants.MPI_RUNNING);
00101             return target.startMPI();
00102         } else {
00103             ProActive.terminateActiveObject(target, true);
00104             throw new IllegalMPIStateException(
00105                 "!!! ERROR: cannot start MPI process " + this.name +
00106                 " Caused by: MPI process has already been started once ");
00107         }
00108     }
00109
00115     public MPIResult reStartMPI() throws IllegalMPIStateException {
00116         MPI_PROXY_LOGGER.debug(
00117             "[MPI Proxy] call reStart method on active object ");
00118         MPI_PROXY_LOGGER.debug("[MPI Proxy] status : " + status);
00119
00120         checkTerminationStatus();
00121
00122         if (!status.equals(MPIConstants.MPI_UNSTARTED)) {
00123             setStatus(MPIConstants.MPI_RUNNING);
00124             target.reinitProcess();
00125             return target.startMPI();
00126         } else {
00127             ProActive.terminateActiveObject(target, true);
00128             throw new IllegalMPIStateException(
00129                 "!!! ERROR: cannot restart MPI process " + this.name +
00130                 " Caused by: no mpi process has been started once before");
00131         }
00132     }
00133
00139     public boolean killMPI() {
00140         MPI_PROXY_LOGGER.debug("[MPI Proxy] Kill MPI Process ");
00141         checkTerminationStatus();
00142
00143         if (status.equals(MPIConstants.MPI_RUNNING)) {
00144             setStatus(MPIConstants.MPI_KILLED);
00145             return target.killMPI();
00146         }
00147         else if (status.equals(MPIConstants.MPI_FINISHED) ||
00148                 status.equals(MPIConstants.MPI_KILLED)) {
00149             return false;
00150         }
00151
00152         else {
00153             ProActive.terminateActiveObject(target, true);
00154             throw new IllegalMPIStateException(
00155                 "!!! ERROR: cannot kill MPI process " + this.name +
00156                 " Caused by: no mpi process has been started once before!");
00157         }
00158     }
00159
00163     public String getStatus() {
00164         checkTerminationStatus();
00165         return status;
00166     }
00167
00172     public void setMPICommandArguments(String arguments) {
00173         target.setMPICommandArguments(arguments);
00174     }
00175
00180     public String getName() {
00181         return this.name;
00182     }
00183
00184     public String toString() {
00185         StringBuilder sb = new StringBuilder(target.toString());
00186         sb.append("\n Status: ");
00187         sb.append(getStatus());
00188         return sb.toString();
00189     }
00190
00191
00192
00193
00194
00195
00196
00197
00198
00199
00200
00201     private void setStatus(String status) {
00202         this.status = status;
00203     }
00204
00205     private void checkTerminationStatus() {
00206         if (target.isFinished() && (!status.equals(MPIConstants.MPI_FINISHED)) &&
00207                 (!status.equals(MPIConstants.MPI_KILLED))) {
00208             status = MPIConstants.MPI_FINISHED;
00209         }
00210     }
00211
00212     public VirtualNode getVn() {
00213         return this.target.getVn();
00214     }
00215
00216
00217
00218
00219     public void newActiveSpmd(String cl) {
00220         this.target.newActiveSpmd(cl);
00221     }
00222
00223     public void newActiveSpmd(String cl, Object[] params) {
00224         this.target.newActiveSpmd(cl, params);
00225     }
00226
00227     public void newActiveSpmd(String cl, Object[][] params) {
00228         this.target.newActiveSpmd(cl, params);
00229     }
00230
00231     public void newActive(String cl, Object[] params, int rank) {
00232         this.target.newActive(cl, params, rank);
00233     }
00234
00235     public ArrayList getClasses() {
00236         return this.target.getClasses();
00237     }
00238
00239     public ArrayList getSpmdClasses() {
00240         return this.target.getSpmdClasses();
00241     }
00242
00243     public Hashtable getClassesParams() {
00244         return this.target.getClassesParams();
00245     }
00246
00247     public Hashtable getSpmdClassesParams() {
00248         return this.target.getSpmdClassesParams();
00249     }
00250
00251     public String getRemoteLibraryPath() {
00252         return this.target.getRemoteLibraryPath();
00253     }
00254 }
