00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.process.mpi;
00032
00033 import org.objectweb.proactive.core.node.Node;
00034 import org.objectweb.proactive.core.process.DependentProcess;
00035 import org.objectweb.proactive.core.process.ExternalProcess;
00036 import org.objectweb.proactive.core.process.JVMNodeProcess;
00037
00038 import java.io.BufferedWriter;
00039 import java.io.FileWriter;
00040 import java.io.IOException;
00041 import java.io.PrintWriter;
00042
00043
00051 public class MPIDependentProcess extends MPIProcess implements DependentProcess {
00052
00057 public MPIDependentProcess() {
00058 super();
00059 this.setTargetProcess(new JVMNodeProcess());
00060 }
00061
00062 public MPIDependentProcess(ExternalProcess targetProcess) {
00063 super(targetProcess);
00064 }
00065
00066
00067
00068
00069 public String getProcessId() {
00070 return "mpidp";
00071 }
00072
00073
00074
00075 public void setDependencyParameters(Object[] dependencyParameters) {
00076 if (this.hostsFileName.compareTo(DEFAULT_HOSTSFILENAME_PATH) == 0) {
00077
00078 String firstHostName = ((Node[]) dependencyParameters)[0].getNodeInformation()
00079 .getName();
00080
00081 StringBuilder sb = new StringBuilder(this.hostsFileName);
00082 sb.append("_").append(firstHostName);
00083 this.hostsFileName = sb.toString();
00084 }
00085
00086 buildHostsFile((Node[]) dependencyParameters);
00087 }
00088
00089 protected void buildHostsFile(Node[] nodes) {
00090 logger.info("Generating machinefile...");
00091 try {
00092 PrintWriter mf_writer;
00093 mf_writer = new PrintWriter(new BufferedWriter(
00094 new FileWriter(hostsFileName)));
00095 for (int i = 0; i < nodes.length; i++) {
00096 mf_writer.println(nodes[i].getNodeInformation().getHostName());
00097 }
00098 mf_writer.close();
00099 } catch (IOException e) {
00100 e.printStackTrace();
00101 }
00102 logger.info("Machinefile generated");
00103 }
00104 }
