00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.locationserver; 00032 00033 import org.objectweb.proactive.ProActive; 00034 import org.objectweb.proactive.core.UniqueID; 00035 import org.objectweb.proactive.core.config.ProActiveConfiguration; 00036 00037 00038 public class LocationServerFactory { 00039 // 00040 // -- PUBLIC MEMBERS ----------------------------------------------- 00041 // 00042 // 00043 // -- CONSTRUCTORS ----------------------------------------------- 00044 // 00045 public LocationServerFactory() { 00046 } 00047 00048 // 00049 // -- PUBLIC METHOD ----------------------------------------------- 00050 // 00051 // public static String getLocationServerClassName() { 00052 // return ProActiveProperties.getLocationServerClass(); 00053 // } 00054 // public static String getLocationServerClassName(UniqueID id) { 00055 // return LocationServerFactory.getLocationServerClassName(); 00056 // } 00057 // public static String getLocationServerName() { 00058 // return ProActiveProperties.getLocationServerRmi(); 00059 // } 00060 // public static String getLocationServerName(UniqueID unique) { 00061 // return LocationServerFactory.getLocationServerName(); 00062 // } 00063 public static LocationServer getLocationServer() { 00064 LocationServer server = null; 00065 try { 00066 server = (LocationServer) ProActive.lookupActive(ProActiveConfiguration.getLocationServerClass(), 00067 ProActiveConfiguration.getLocationServerRmi()); 00068 } catch (Exception e) { 00069 return null; 00070 } 00071 return server; 00072 // try { 00073 // Object t = null; 00074 // t.toString(); 00075 // } catch (Exception e) { 00076 // System.out.println("-----------------------"); 00077 // e.printStackTrace(); 00078 // System.out.println("-----------------------"); 00079 // } 00080 // 00081 // return null; 00082 } 00083 00089 public static LocationServer getLocationServer(UniqueID id) { 00090 return LocationServerFactory.getLocationServer(); 00091 } 00092 }
1.5.1
