00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.loadbalancing;
00032
00033 import java.util.Iterator;
00034 import java.util.ArrayList;
00035
00036 import org.objectweb.proactive.ActiveObjectCreationException;
00037 import org.objectweb.proactive.ProActive;
00038 import org.objectweb.proactive.core.node.Node;
00039 import org.objectweb.proactive.core.node.NodeException;
00040 import org.objectweb.proactive.loadbalancing.metrics.MetricFactory;
00041
00042 public class LoadBalancing {
00043         private static ArrayList<LoadBalancer> loadBalancers = new ArrayList<LoadBalancer>();
00044         private static MetricFactory mf;
00045         private static boolean activated = false;
00046         private static InformationRecover ir;
00047
00048         public static void activateOn(Node[] nodes, MetricFactory mf) {
00049                 LoadBalancing.mf = mf;
00050                 activated = true;
00051                 LoadBalancer lb = null;
00052
00053                 try {
00054                         ir = (InformationRecover) ProActive.newActive(
00055                                         InformationRecover.class.getName(), null);
00056
00057                         for (int i = 0; i < nodes.length; i++) {
00058                                 lb = (LoadBalancer) ProActive.newActive(LoadBalancer.class
00059                                                 .getName(), new Object[]{mf}, nodes[i]);
00060                                 loadBalancers.add(lb);
00061
00062                                 lb = null;
00063                         }
00064
00065                         Iterator<LoadBalancer> it = loadBalancers.iterator();
00066                         while (it.hasNext()) {
00067                                 lb = it.next();
00068                                 lb.init(loadBalancers,ir);
00069                                 lb = null;
00070
00071                         }
00072                 }
00073                 catch (ActiveObjectCreationException e)         {e.printStackTrace();}
00074                 catch (NodeException e)                                         {e.printStackTrace();}
00075
00076         }
00077
00078         public static void activate(MetricFactory mf) {
00079                 LoadBalancing.mf = mf;
00080                 activated = true;
00081
00082                 try {
00083                         ir = (InformationRecover) ProActive.newActive(
00084                                         InformationRecover.class.getName(), null);
00085
00086
00087                 }
00088                 catch (ActiveObjectCreationException e)         {e.printStackTrace();}
00089                 catch (NodeException e)                                         {e.printStackTrace();}
00090
00091         }
00092
00093         public static void kill() {
00094                 activated = false;
00095
00096                 ProActive.terminateActiveObject(ir,true);
00097                 LoadBalancer lb;
00098                 Iterator<LoadBalancer> it = loadBalancers.iterator();
00099                 while (it.hasNext()) {
00100                         lb = it.next();
00101                         ProActive.terminateActiveObject(lb,true);
00102                 }
00103         }
00104
00105         public static void addNode(Node node){
00106                 if(! activated)
00107                         return;
00108
00109                 try {
00110                         LoadBalancer lb = (LoadBalancer) ProActive.newActive(LoadBalancer.class
00111                                         .getName(), new Object[]{mf}, node);
00112                         loadBalancers.add(lb);
00113                         lb.init(loadBalancers,ir);
00114                         lb.notifyLoadBalancers();
00115
00116                 }
00117                 catch (ActiveObjectCreationException e)         {e.printStackTrace();}
00118                 catch (NodeException e)                                         {e.printStackTrace();}
00119
00120         }
00121 }
