00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.loadbalancing; 00032 00033 import java.io.Serializable; 00034 import java.util.Map; 00035 00036 import org.objectweb.proactive.core.descriptor.services.TechnicalService; 00037 import org.objectweb.proactive.core.node.Node; 00038 import org.objectweb.proactive.loadbalancing.metrics.MetricFactory; 00039 00040 public class LoadBalancingTS implements TechnicalService, Serializable { 00041 00042 public void init(Map argValues) { 00043 // TODO Auto-generated method stub 00044 String metricFactoryName = (String) argValues.get("MetricFactory"); 00045 try { 00046 MetricFactory mf = (MetricFactory) Class.forName(metricFactoryName) 00047 .newInstance(); 00048 LoadBalancing.activate(mf); 00049 } catch (InstantiationException e) { 00050 // TODO Auto-generated catch block 00051 e.printStackTrace(); 00052 } catch (IllegalAccessException e) { 00053 // TODO Auto-generated catch block 00054 e.printStackTrace(); 00055 } catch (ClassNotFoundException e) { 00056 // TODO Auto-generated catch block 00057 e.printStackTrace(); 00058 } 00059 00060 } 00061 00062 public void apply(Node node) { 00063 LoadBalancing.addNode(node); 00064 00065 } 00066 00067 }
1.5.1
