00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.adl.vnexportation; 00032 00033 import java.util.ArrayList; 00034 import java.util.Iterator; 00035 import java.util.List; 00036 00037 00055 public class LinkedVirtualNode { 00056 private List composingVirtualNodes; 00057 private LinkedVirtualNode composer = null; 00058 private String componentName; 00059 private String virtualNodeName; 00060 private boolean isMultiple = false; 00061 boolean isLeaf = false; 00062 00063 // /private boolean selfExported = false; 00064 public final static String EMPTY_COMPONENT_NAME = "component_name"; 00065 public final static String EMPTY_VIRTUAL_NODE_NAME = "virtual_node_name"; 00066 00072 public LinkedVirtualNode(String componentName, String virtualNodeName) { 00073 this.componentName = componentName; 00074 this.virtualNodeName = virtualNodeName; 00075 composingVirtualNodes = new ArrayList(); 00076 } 00077 00078 void setComposer(LinkedVirtualNode composer) { 00079 this.composer = composer; 00080 } 00081 00087 public boolean addComposingVirtualNode(LinkedVirtualNode vn) { 00088 // System.out.println("ADDING " + vn.toString() + " \nTO : " + toString()); 00089 setMultiple(vn.isMultiple()); 00090 if (!composingVirtualNodes.contains(vn)) { 00091 composingVirtualNodes.add(vn); 00092 vn.setComposer(this); 00093 return true; 00094 } 00095 return false; 00096 } 00097 00102 public List getComposingVirtualNodes() { 00103 return composingVirtualNodes; 00104 } 00105 00110 public String getComposingVirtualNodesAsString() { 00111 Iterator iter = getComposingVirtualNodes().iterator(); 00112 StringBuffer buff = new StringBuffer(); 00113 while (iter.hasNext()) { 00114 LinkedVirtualNode element = (LinkedVirtualNode) iter.next(); 00115 if (element.getDefiningComponentName().equals(EMPTY_COMPONENT_NAME) || 00116 element.getVirtualNodeName().equals(EMPTY_VIRTUAL_NODE_NAME)) { 00117 continue; 00118 } 00119 buff.append(element.getDefiningComponentName() + "." + 00120 element.getVirtualNodeName()); 00121 buff.append(";"); 00122 } 00123 return buff.toString(); 00124 } 00125 00130 public String getVirtualNodeName() { 00131 return virtualNodeName; 00132 } 00133 00138 public String getCompleteNameBeforeComposition() { 00139 return componentName + '.' + virtualNodeName; 00140 } 00141 00146 public String getExportedVirtualNodeNameAfterComposition() { 00147 return ((composer == null) ? virtualNodeName 00148 : composer.getExportedVirtualNodeNameAfterComposition()); 00149 } 00150 00155 public String getExportedVirtualNodeNameBeforeComposition() { 00156 return ((composer == null) ? virtualNodeName 00157 : composer.getVirtualNodeName()); 00158 } 00159 00164 public void setMultiple(boolean yes) { 00165 if (yes) { 00166 isMultiple = true; 00167 } 00168 } 00169 00174 public boolean isMultiple() { 00175 return isMultiple; 00176 } 00177 00182 public boolean isExported() { 00183 return composingVirtualNodes.size() > 0; 00184 } 00185 00190 public String getDefiningComponentName() { 00191 return componentName; 00192 } 00193 00199 // public void setSelfExported() { 00200 // selfExported=true; 00201 // } 00202 00206 public boolean isSelfExported() { 00207 if (composer == null) { 00208 return false; 00209 } 00210 00211 // FIXME find a better way 00212 return (isLeaf || 00213 composer.getDefiningComponentName().equals(getDefiningComponentName())); 00214 } 00215 00222 public boolean isComposedFrom(String componentName, String virtualNodeName) { 00223 Iterator it = composingVirtualNodes.iterator(); 00224 while (it.hasNext()) { 00225 LinkedVirtualNode lvn = (LinkedVirtualNode) it.next(); 00226 if (lvn.getDefiningComponentName().equals(componentName)) { 00227 if (lvn.getVirtualNodeName().equals(virtualNodeName)) { 00228 return true; 00229 } 00230 } 00231 } 00232 return false; 00233 } 00234 00239 public LinkedVirtualNode getComposer() { 00240 return composer; 00241 } 00242 00243 public void setIsLeaf() { 00244 isLeaf = true; 00245 } 00246 00247 public boolean isLeaf() { 00248 return isLeaf; 00249 } 00250 00251 public String toString() { 00252 StringBuffer buffer = new StringBuffer(); 00253 if (composer == this) { 00254 buffer.append(getDefiningComponentName() + "." + 00255 getVirtualNodeName() + "<--" + componentName + "." + 00256 virtualNodeName + "-->{"); 00257 } else if (composer != null) { 00258 buffer.append(composer.getDefiningComponentName() + "." + 00259 composer.getVirtualNodeName() + "<--" + componentName + "." + 00260 virtualNodeName + "-->{"); 00261 } 00262 Iterator it = composingVirtualNodes.iterator(); 00263 while (it.hasNext()) { 00264 LinkedVirtualNode lvn = (LinkedVirtualNode) it.next(); 00265 if (lvn == this) { 00266 continue; 00267 } 00268 buffer.append(lvn.toString()); 00269 } 00270 return buffer.append("}").toString(); 00271 } 00272 }
1.5.1
