00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.group.topology; 00032 00033 import org.objectweb.proactive.core.group.Group; 00034 import org.objectweb.proactive.core.mop.ConstructionOfReifiedObjectFailedException; 00035 00036 00042 public class Line extends TopologyGroup { // implements Topology1D { 00043 00045 protected int width; 00046 00053 public Line(Group g, int size) 00054 throws ConstructionOfReifiedObjectFailedException { 00055 super(g, size); 00056 this.width = size; 00057 } 00058 00063 public int getWidth() { 00064 return this.width; 00065 } 00066 00072 public int getX(Object o) { 00073 return this.indexOf(o); 00074 } 00075 00081 public Object left(Object o) { 00082 int position = this.indexOf(o); 00083 if (position != 0) { 00084 return this.get(position - 1); 00085 } else { 00086 return null; 00087 } 00088 } 00089 00095 public Object right(Object o) { 00096 int position = this.indexOf(o); 00097 if (position != (this.getWidth() - 1)) { 00098 return this.get(position + 1); 00099 } else { 00100 return null; 00101 } 00102 } 00103 }
1.5.1
