00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.representative; 00032 00033 import java.io.Serializable; 00034 00035 import org.objectweb.proactive.core.UniqueID; 00036 00037 00044 public class ItfID implements Serializable { 00045 private String itfName; 00046 private UniqueID componentBodyID; 00047 boolean isClientItf = false; 00048 00049 public ItfID(String itfName, 00050 UniqueID componentBodyID) { 00051 this.itfName = itfName; 00052 this.componentBodyID = componentBodyID; 00053 } 00054 00055 public String getItfName() { 00056 return itfName; 00057 } 00058 00059 public UniqueID getComponentBodyID() { 00060 return componentBodyID; 00061 } 00062 00063 public int hashCode() { 00064 return componentBodyID.hashCode() + itfName.hashCode(); 00065 } 00066 00067 public boolean equals(Object o) { 00068 //System.out.println("Now checking for equality"); 00069 if (o instanceof ItfID) { 00070 return (itfName.equals(((ItfID) o).itfName) && 00071 (componentBodyID.equals(((ItfID) o).componentBodyID))); 00072 } else { 00073 return false; 00074 } 00075 } 00076 }
1.5.1
