00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.calcium;
00032
00033 import java.io.Serializable;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.calcium.exceptions.PanicException;
00037 import org.objectweb.proactive.calcium.interfaces.Instruction;
00038 import org.objectweb.proactive.calcium.statistics.Timer;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00061 public class Interpreter implements Serializable {
00062         static Logger logger = ProActiveLogger.getLogger(Loggers.SKELETONS_STRUCTURE);
00063
00064         public Interpreter(){
00065         }
00066
00067         public <T> Task<T> interpret(Task<T> task){
00068
00069                 Timer timer=new Timer(true);
00070                 while(task.hasInstruction()){
00071                         if(logger.isDebugEnabled()){
00072                                 logger.debug("--Stack Top-- Task="+task.getId()+" "+task.getObject());
00073                                 String tmp="";
00074                                 for(Instruction c:task.getStack()) tmp=c+"\n"+tmp;
00075                                 tmp=tmp.trim();
00076                                 logger.debug(tmp);
00077                         }
00078
00079
00080                         Instruction<T> inst = task.popInstruction();
00081
00082
00083                         int oldId=task.getId();
00084
00085                         try {
00086                                 task=inst.compute(task);
00087                         } catch (Exception e) {
00088                                 task.pushInstruction(inst);
00089                                 task.setException(e);
00090                                 return task;
00091                         }
00092
00093                         if(oldId!=task.getId()){
00094                                 String msg = "Panic error, task id changed while interpreting! "+oldId+"->"+task.getId();
00095                                 task.pushInstruction(inst);
00096                                 task.setException(new PanicException(msg));
00097                                 logger.error(msg);
00098                                 return task;
00099                         }
00100
00101
00102                         if(task.hasReadyChildTask()){
00103                                 timer.stop();
00104                                 task.getStats().addComputationTime(timer.getTime());
00105                                 return task;
00106                         }
00107                 }
00108
00109
00110                 timer.stop();
00111                 task.getStats().addComputationTime(timer.getTime());
00112                 return task;
00113         }
00114 }
