00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process; 00032 00033 import java.io.IOException; 00034 00035 import java.util.ArrayList; 00036 00037 00046 public class IndependentListProcess 00047 extends AbstractSequentialListProcessDecorator { 00048 public IndependentListProcess() { 00049 super(); 00050 } 00051 00052 public IndependentListProcess(ArrayList processes) { 00053 super(); 00054 this.processes = processes; 00055 } 00056 00057 protected ExternalProcess createProcess() { 00058 // TODO Auto-generated method stub 00059 return null; 00060 } 00061 00062 public String getHostname() { 00063 // TODO Auto-generated method stub 00064 return null; 00065 } 00066 00067 public void setHostname(String hostname) { 00068 // TODO Auto-generated method stub 00069 } 00070 00071 public boolean isHierarchical() { 00072 // TODO Auto-generated method stub 00073 return false; 00074 } 00075 00076 public boolean isDependent() { 00077 // TODO Auto-generated method stub 00078 return false; 00079 } 00080 00081 public void startProcess() throws IOException { 00082 // TODO Auto-generated method stub 00083 } 00084 }
1.5.1
