org/objectweb/proactive/calcium/skeletons/If.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.calcium.skeletons;
00032
00033 import java.util.Vector;
00034
00035 import org.objectweb.proactive.calcium.Task;
00036 import org.objectweb.proactive.calcium.interfaces.Condition;
00037 import org.objectweb.proactive.calcium.interfaces.Instruction;
00038 import org.objectweb.proactive.calcium.interfaces.Skeleton;
00039 import org.objectweb.proactive.calcium.statistics.Timer;
00040
00050 public class If<T> implements Skeleton<T>, Instruction<T> {
00051
00052         Condition<T> cond;
00053         Skeleton<T> ifChild, elseChild;
00054         public If(Condition<T> cond, Skeleton<T> ifChild, Skeleton<T> elseChild){
00055
00056                 this.cond=cond;
00057                 this.ifChild=ifChild;
00058                 this.elseChild=elseChild;
00059         }
00060
00061         public Vector<Instruction<T>> getInstructionStack() {
00062
00063                 Vector<Instruction<T>> v = new Vector<Instruction<T>>();
00064                 v.add(this);
00065                 return v;
00066         }
00067
00068
00069         public Task<T> compute(Task<T> t) throws Exception{
00070
00071                 Vector<Instruction<T>> childStack;
00072                 Timer timer = new Timer();
00073                 boolean evalCondition= cond.evalCondition(t.getObject());
00074                 timer.stop();
00075
00076                 if(evalCondition){
00077                         childStack= ifChild.getInstructionStack();
00078                 }
00079                 else{
00080                         childStack= elseChild.getInstructionStack();
00081                 }
00082
00083                 Vector<Instruction<T>> taskStack = t.getStack();
00084                 taskStack.addAll(childStack);
00085                 t.setStack(taskStack);
00086                 t.getStats().getWorkout().track(cond, timer);
00087
00088                 return t;
00089         }
00090 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
