org/objectweb/proactive/core/runtime/ibis/IbisRuntimeFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.runtime.ibis;
00032
00033 import org.objectweb.proactive.core.ProActiveException;
00034 import org.objectweb.proactive.core.rmi.ClassServerHelper;
00035 import org.objectweb.proactive.core.rmi.RegistryHelper;
00036 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00037 import org.objectweb.proactive.core.runtime.ProActiveRuntimeAdapterImpl;
00038 import org.objectweb.proactive.core.runtime.RemoteProActiveRuntime;
00039 import org.objectweb.proactive.core.runtime.RuntimeFactory;
00040 import org.objectweb.proactive.core.util.IbisProperties;
00041 import org.objectweb.proactive.core.util.UrlBuilder;
00042
00043 import ibis.rmi.AlreadyBoundException;
00044 import ibis.rmi.RemoteException;
00045
00046
00047 public class IbisRuntimeFactory extends RuntimeFactory {
00048
00049     static {
00050         IbisProperties.load();
00051     }
00052
00053     //protected final static int MAX_RETRY = 5;
00054     //protected java.util.Random random;
00055     protected static RegistryHelper registryHelper = new RegistryHelper();
00056     protected static ClassServerHelper classServerHelper = new ClassServerHelper();
00057     private static ProActiveRuntime defaultRmiRuntime = null;
00058
00059     //
00060     // -- CONSTRUCTORS -----------------------------------------------
00061     //
00062     public IbisRuntimeFactory() throws java.io.IOException {
00063         if ((System.getSecurityManager() == null) &&
00064                 !("false".equals(System.getProperty("proactive.securitymanager")))) {
00065             System.setSecurityManager(new java.rmi.RMISecurityManager());
00066         }
00067
00068         registryHelper.initializeRegistry();
00069     }
00070
00071     //
00072     // -- PUBLIC METHODS -----------------------------------------------
00073     //
00074     public static void setClassServerClasspath(String v) {
00075         classServerHelper.setClasspath(v);
00076     }
00077
00078     public static void setShouldCreateClassServer(boolean v) {
00079         classServerHelper.setShouldCreateClassServer(v);
00080     }
00081
00082     public static void setRegistryPortNumber(int v) {
00083         registryHelper.setRegistryPortNumber(v);
00084     }
00085
00086     public static void setShouldCreateRegistry(boolean v) {
00087         registryHelper.setShouldCreateRegistry(v);
00088     }
00089
00090     //
00091     // -- PROTECTED METHODS -----------------------------------------------
00092     //
00093     //  protected ProActiveRuntime createRemoteRuntimeImpl(String s, boolean replacePreviousBinding) throws ProActiveException {
00094     //    return createRuntimeAdapter(s, replacePreviousBinding);
00095     //  }
00096     protected synchronized ProActiveRuntime getProtocolSpecificRuntimeImpl()
00097         throws ProActiveException {
00098         //return createRuntimeAdapter(s,false);
00099         if (defaultRmiRuntime == null) {
00100             defaultRmiRuntime = createRuntimeAdapter();
00101         }
00102
00103         return defaultRmiRuntime;
00104     }
00105
00106     protected ProActiveRuntime getRemoteRuntimeImpl(String s)
00107         throws ProActiveException {
00108         //if (s == null) return null;
00109         if (runtimeLogger.isDebugEnabled()) {
00110             runtimeLogger.debug("looking for " + s);
00111         }
00112
00113         try {
00114             RemoteProActiveRuntime remoteProActiveRuntime = (RemoteProActiveRuntime) ibis.rmi.Naming.lookup(UrlBuilder.removeProtocol(
00115                         s, "ibis:"));
00116
00117             if (runtimeLogger.isDebugEnabled()) {
00118                 runtimeLogger.debug(remoteProActiveRuntime.getClass().getName());
00119             }
00120
00121             return createRuntimeAdapter(remoteProActiveRuntime);
00122         } catch (ibis.rmi.RemoteException e) {
00123             throw new ProActiveException("Remote", e);
00124         } catch (ibis.rmi.NotBoundException e) {
00125             throw new ProActiveException("NotBound", e);
00126         } catch (java.net.MalformedURLException e) {
00127             throw new ProActiveException("Malformed URL:" + s, e);
00128         }
00129     }
00130
00131     protected ProActiveRuntimeAdapterImpl createRuntimeAdapter()
00132         throws ProActiveException {
00133         IbisProActiveRuntimeImpl impl;
00134
00135         try {
00136             impl = new IbisProActiveRuntimeImpl();
00137         } catch (RemoteException e) {
00138             throw new ProActiveException("Cannot create the RemoteProActiveRuntimeImpl",
00139                 e);
00140         } catch (AlreadyBoundException e) {
00141             throw new ProActiveException("Cannot bind remoteProactiveRuntime", e);
00142         }
00143
00144         return new ProActiveRuntimeAdapterImpl(impl);
00145     }
00146
00147     protected static RegistryHelper getRegistryHelper() {
00148         return registryHelper;
00149     }
00150
00151     //
00152     // -- PRIVATE METHODS -----------------------------------------------
00153     //
00154 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
