org/objectweb/proactive/core/body/ft/protocols/cic/managers/HalfFTManagerCIC.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.ft.protocols.cic.managers;
00032
00033 import java.net.MalformedURLException;
00034 import java.rmi.Naming;
00035 import java.rmi.NotBoundException;
00036 import java.rmi.RemoteException;
00037
00038 import org.apache.log4j.Logger;
00039 import org.objectweb.proactive.core.ProActiveException;
00040 import org.objectweb.proactive.core.ProActiveRuntimeException;
00041 import org.objectweb.proactive.core.body.AbstractBody;
00042 import org.objectweb.proactive.core.body.UniversalBody;
00043 import org.objectweb.proactive.core.body.ft.checkpointing.CheckpointInfo;
00044 import org.objectweb.proactive.core.body.ft.internalmsg.FTMessage;
00045 import org.objectweb.proactive.core.body.ft.protocols.FTManager;
00046 import org.objectweb.proactive.core.body.ft.protocols.cic.infos.MessageInfoCIC;
00047 import org.objectweb.proactive.core.body.ft.servers.location.LocationServer;
00048 import org.objectweb.proactive.core.body.reply.Reply;
00049 import org.objectweb.proactive.core.body.request.Request;
00050 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00051 import org.objectweb.proactive.core.util.log.Loggers;
00052 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00053 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00054
00055
00062 public class HalfFTManagerCIC extends FTManager {
00063     // message infos
00064     private MessageInfoCIC forSentMessage;
00065
00066     //logger
00067     protected static Logger logger = ProActiveLogger.getLogger(Loggers.FAULT_TOLERANCE_PML);
00068
00072     public int init(AbstractBody owner) throws ProActiveException {
00073         //super.init(owner);
00074         // a half body need only a location server...
00075         try {
00076             String urlGlobal = ProActiveConfiguration.getGlobalFTServer();
00077             if (urlGlobal != null) {
00078                 this.location = (LocationServer) (Naming.lookup(urlGlobal));
00079             } else {
00080                 String urlLocation = ProActiveConfiguration.getLocationServer();
00081                 if (urlLocation != null) {
00082                     this.location = (LocationServer) (Naming.lookup(urlLocation));
00083                 } else {
00084                     throw new ProActiveException(
00085                         "Unable to init HalfFTManager : servers are not correctly set");
00086                 }
00087             }
00088             this.storage = null;
00089             this.recovery = null;
00090         } catch (MalformedURLException e) {
00091             throw new ProActiveException("Unable to init HalfFTManager : FT is disable.",
00092                 e);
00093         } catch (RemoteException e) {
00094             throw new ProActiveException("Unable to init HalfFTManager : FT is disable.",
00095                 e);
00096         } catch (NotBoundException e) {
00097             throw new ProActiveException("Unable to init HalfFTManager : FT is disable.",
00098                 e);
00099         }
00100         this.forSentMessage = new MessageInfoCIC();
00101         this.forSentMessage.fromHalfBody = true;
00102         logger.info(" CIC fault-tolerance is enabled for half body " +
00103             this.ownerID);
00104         return 0;
00105     }
00106
00107     public int onReceiveReply(Reply reply) {
00108         reply.setFTManager(this);
00109         return 0;
00110     }
00111
00112     public int onDeliverReply(Reply reply) {
00113         return FTManager.NON_FT;
00114     }
00115
00116     public int onSendRequestBefore(Request request) {
00117         request.setMessageInfo(this.forSentMessage);
00118         return 0;
00119     }
00120
00121     public int onSendReplyBefore(Reply reply) {
00122         reply.setMessageInfo(this.forSentMessage);
00123         return 0;
00124     }
00125
00126     public int onSendRequestAfter(Request request, int rdvValue,
00127         UniversalBody destination) throws RenegotiateSessionException {
00128         if (rdvValue == FTManagerCIC.RESEND_MESSAGE) {
00129             try {
00130                 request.resetSendCounter();
00131                 request.setIgnoreIt(false);
00132                 Thread.sleep(FTManagerCIC.TIME_TO_RESEND);
00133                 int rdvValueBis = sendRequest(request, destination);
00134                 return this.onSendRequestAfter(request, rdvValueBis, destination);
00135             } catch (RenegotiateSessionException e1) {
00136                 throw e1;
00137             } catch (InterruptedException e) {
00138                 e.printStackTrace();
00139             }
00140         }
00141         return 0;
00142     }
00143
00144     public synchronized int onSendReplyAfter(Reply reply, int rdvValue,
00145         UniversalBody destination) {
00146         if (rdvValue == FTManagerCIC.RESEND_MESSAGE) {
00147             try {
00148                 reply.setIgnoreIt(false);
00149                 Thread.sleep(FTManagerCIC.TIME_TO_RESEND);
00150                 int rdvValueBis = sendReply(reply, destination);
00151                 return this.onSendReplyAfter(reply, rdvValueBis, destination);
00152             } catch (InterruptedException e) {
00153                 e.printStackTrace();
00154             }
00155         }
00156         return 0;
00157     }
00158
00160     // UNCALLABLE METHODS //
00162     public int onReceiveRequest(Request request) {
00163         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00164     }
00165
00166     public int onDeliverRequest(Request request) {
00167         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00168     }
00169
00170     public int onServeRequestBefore(Request request) {
00171         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00172     }
00173
00174     public int onServeRequestAfter(Request request) {
00175         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00176     }
00177
00178     public int beforeRestartAfterRecovery(CheckpointInfo ci, int inc) {
00179         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00180     }
00181
00182     public int getIncarnation() {
00183         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00184     }
00185
00186     public Object handleFTMessage(FTMessage fte) {
00187         throw new ProActiveRuntimeException(HALF_BODY_EXCEPTION_MESSAGE);
00188     }
00189 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
