00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.gen; 00032 00033 import java.io.Serializable; 00034 import java.lang.reflect.InvocationHandler; 00035 import java.lang.reflect.Method; 00036 00037 import org.apache.log4j.Logger; 00038 import org.objectweb.proactive.core.util.log.Loggers; 00039 import org.objectweb.proactive.core.util.log.ProActiveLogger; 00040 00041 public class GatherItfAdapterProxy implements InvocationHandler, Serializable { 00042 00043 private static Logger logger = ProActiveLogger.getLogger(Loggers.COMPONENTS_GATHERCAST); 00044 00045 Object delegatee = null; 00046 00047 00048 public GatherItfAdapterProxy(Object delegatee) { 00049 this.delegatee = delegatee; 00050 } 00051 00052 00053 /* (non-Javadoc) 00054 * @see java.lang.reflect.InvocationHandler#invoke(java.lang.Object, java.lang.reflect.Method, java.lang.Object[]) 00055 */ 00056 public Object invoke(Object proxy, Method method, Object[] args) 00057 throws Throwable { 00058 try { 00059 if (logger.isDebugEnabled()) { 00060 logger.debug("gather proxy trying to invoke method : " + method.toGenericString()); 00061 } 00062 00063 // Method serverMethod = GatherBindingChecker.searchMatchingMethod(method, delegatee.getClass().getMethods()); 00064 // need to change invocation parameters 00065 Object result = delegatee.getClass().getMethod(method.getName(), method.getParameterTypes()).invoke(delegatee, args); 00066 return result; 00067 } catch (Throwable t) { 00068 t.printStackTrace(); 00069 throw t; 00070 } 00071 00072 } 00073 00074 00075 }
 1.5.1
