00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.gen;
00032
00033 import java.lang.reflect.Method;
00034 import java.lang.reflect.ParameterizedType;
00035 import java.util.List;
00036
00037 import javassist.ClassPool;
00038 import javassist.CtClass;
00039 import javassist.CtMethod;
00040 import javassist.CtNewMethod;
00041
00042 import org.apache.log4j.Logger;
00043 import org.objectweb.proactive.core.component.exceptions.InterfaceGenerationFailedException;
00044 import org.objectweb.proactive.core.component.type.ProActiveInterfaceType;
00045 import org.objectweb.proactive.core.util.ClassDataCache;
00046 import org.objectweb.proactive.core.util.log.Loggers;
00047 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00048
00049 public class GatherInterfaceGenerator {
00050
00051     protected static final transient ClassPool pool = ClassPool.getDefault();
00052     private static Logger gatherLogger = ProActiveLogger.getLogger(Loggers.COMPONENTS_GATHERCAST);
00053
00054     public static Class generateInterface(ProActiveInterfaceType itfType) throws InterfaceGenerationFailedException {
00055         Class generated = null;
00056         String gatherProxyItfName = Utils.getGatherProxyItfClassName(itfType);
00057         try {
00058
00059
00060             generated = Thread.currentThread().getContextClassLoader().loadClass(gatherProxyItfName);
00061         } catch (ClassNotFoundException cnfe) {
00062             byte[] bytecode = generateInterfaceByteCode(gatherProxyItfName);
00063
00064             try {
00065
00066             generated = Utils.defineClass(gatherProxyItfName, bytecode);
00067             } catch (Exception e) {
00068                 e.printStackTrace();
00069                 return null;
00070             }
00071         }
00072
00073         return generated;
00074     }
00075
00076
00077
00078
00079     static byte[] generateInterfaceByteCode(String gatherProxyItfName) {
00080         if (ClassDataCache.instance().getClassData(gatherProxyItfName) != null) {
00081             return ClassDataCache.instance().getClassData(gatherProxyItfName);
00082         }
00083         try {
00084             Class serverItfClass = Class.forName(Utils.getInterfaceSignatureFromGathercastProxyClassName(gatherProxyItfName));
00085             CtClass repGatherItfClass = pool.makeInterface(gatherProxyItfName);
00086         Method[] serverItfMethods = serverItfClass.getMethods();
00087
00088         CtMethod[] repServerItfMethods = new CtMethod[serverItfMethods.length];
00089
00090         for (int i = 0; i < serverItfMethods.length; i++) {
00091
00092             CtClass repReturnType = null;
00093             java.lang.reflect.Type returnType = serverItfMethods[i].getGenericReturnType();
00094             CtClass[] repParameterTypes = new CtClass[serverItfMethods[i].getParameterTypes().length];
00095
00096             if (Void.TYPE == returnType) {
00097                 repReturnType = CtClass.voidType;
00098             } else {
00099                 if (!(returnType instanceof ParameterizedType)) {
00100                     throw new InterfaceGenerationFailedException("gather method " + serverItfMethods[i].toGenericString() + " in gather interface of signature " + serverItfClass.getName() + " must return a parameterized list or void");
00101                 }
00102
00103                 if (!(List.class.isAssignableFrom((Class)((ParameterizedType)returnType).getRawType()))) {
00104                     throw new InterfaceGenerationFailedException("gather method " + serverItfMethods[i].toGenericString() + " in gather interface " + serverItfClass.getName() + " must return a parameterized list or void");
00105                 }
00106                 java.lang.reflect.Type[] actualTypeArguments = ((ParameterizedType)returnType).getActualTypeArguments();
00107                 if (actualTypeArguments.length != 1) {
00108                     throw new InterfaceGenerationFailedException("gather method " + serverItfMethods[i].toGenericString() + " in gather interface " + serverItfClass.getName() + " must return a parameterized type with one parameter");
00109                 }
00110                 repReturnType = pool.get(((Class)(((ParameterizedType)returnType).getActualTypeArguments()[0])).getName());
00111             }
00112
00113             java.lang.reflect.Type[] paramTypes = serverItfMethods[i].getGenericParameterTypes();
00114             for (int j = 0; j < paramTypes.length; j++) {
00115                 java.lang.reflect.Type paramType = paramTypes[j];
00116                 if (!(paramType instanceof ParameterizedType)) {
00117                     throw new InterfaceGenerationFailedException("gather method " + serverItfMethods[i].toGenericString() + " in gather interface " + serverItfClass.getName() + " must have type-parameterized parameter types");
00118                 }
00119                 java.lang.reflect.Type[] actualTypeArguments = ((ParameterizedType)paramType).getActualTypeArguments();
00120                 if (actualTypeArguments.length != 1) {
00121                     throw new InterfaceGenerationFailedException("gather method " + serverItfMethods[i].toGenericString() + " in gather interface " + serverItfClass.getName() + " must have type-parameterized parameters with only one parameterizing element");
00122                 }
00123                 repParameterTypes[j] = pool.get(((Class)actualTypeArguments[0]).getName());
00124             }
00125
00126
00127             Class[] exceptions = serverItfMethods[i].getExceptionTypes();
00128             CtClass[] repExceptions = new CtClass[exceptions.length];
00129             for (int j = 0; j < exceptions.length; j++) {
00130                 repExceptions[j] = pool.get(exceptions[j].getName());
00131             }
00132
00133
00134             repServerItfMethods[i] = CtNewMethod.abstractMethod(repReturnType, serverItfMethods[i].getName(), repParameterTypes, repExceptions, repGatherItfClass);
00135
00136             repGatherItfClass.addMethod(repServerItfMethods[i]);
00137
00138
00139         }
00140
00141
00142
00143
00144
00145         byte[] bytecode = repGatherItfClass.toBytecode();
00146         ClassDataCache.instance().addClassData(gatherProxyItfName,
00147                         repGatherItfClass.toBytecode());
00148
00149
00150
00151
00152
00153
00154
00155
00156         return bytecode;
00157         } catch (Exception e) {
00158             e.printStackTrace();
00159             gatherLogger.error("cannot generate gather proxy interface class " + gatherProxyItfName );
00160             return null;
00161         }
00162
00163     }
00164
00165 }
