org/objectweb/proactive/core/body/future/FutureResult.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.future;
00032
00033 import java.io.Serializable;
00034
00035 import org.objectweb.proactive.core.exceptions.manager.ExceptionHandler;
00036 import org.objectweb.proactive.core.exceptions.proxy.ProxyNonFunctionalException;
00037
00038 class ThisIsNotAnException extends Exception {
00039         public ThisIsNotAnException() {
00040                 super("This is the call in the proxy");
00041         }
00042 }
00043
00048 public class FutureResult implements Serializable {
00049
00051     private Object result;
00052
00054     private Throwable exception;
00055
00057     private ProxyNonFunctionalException nfe;
00058
00059     public FutureResult(Object result, Throwable exception,
00060         ProxyNonFunctionalException nfe) {
00061         this.result = result;
00062         this.exception = exception;
00063         this.nfe = nfe;
00064     }
00065
00066     public Throwable getExceptionToRaise() {
00067         return exception;
00068     }
00069
00070     public ProxyNonFunctionalException getNFE() {
00071         return nfe;
00072     }
00073
00074     public Object getResult() {
00075         if (exception != null) {
00076             ExceptionHandler.throwException(exception);
00077         }
00078
00079         return result;
00080     }
00081
00082     public String toString() {
00083         String str = "[";
00084         if (nfe != null) {
00085             str += ("nfe:" + nfe.getClass().getName());
00086         } else if (exception != null) {
00087             str += ("ex:" + exception.getClass().getName());
00088         } else if (result != null) {
00089             str += result.getClass().getName();
00090         } else {
00091             str += "null";
00092         }
00093
00094         return str + "]";
00095     }
00096
00097     public void augmentException(StackTraceElement[] stackTrace) {
00098         Throwable cause = (exception == null) ? nfe : exception;
00099         if (cause != null && stackTrace != null) {
00100                 while (cause.getCause() != null) {
00101                         cause = cause.getCause();
00102                 }
00103                 Exception origCause = new ThisIsNotAnException();
00104                 origCause.setStackTrace(stackTrace);
00105                 cause.initCause(origCause);
00106         }
00107     }
00108 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
