00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.scilab.util; 00032 00036 public class FutureDoubleMatrix { 00037 private double[] res; 00038 private String name; 00039 private int nbRow; 00040 private int nbCol; 00041 00042 public FutureDoubleMatrix(String name, int nbRow, int nbCol){ 00043 this.name = name; 00044 this.nbRow = nbRow; 00045 this.nbCol = nbCol; 00046 } 00047 00048 public synchronized void set(double[] res) { 00049 this.res = res; 00050 this.notifyAll(); 00051 } 00052 00053 public synchronized double[] get() { 00054 try{ 00055 while (res == null) { 00056 this.wait(); 00057 } 00058 } 00059 catch(InterruptedException e){ 00060 } 00061 00062 return res; 00063 } 00064 00065 public String getName() { 00066 return name; 00067 } 00068 00069 public int getNbCol() { 00070 return nbCol; 00071 } 00072 00073 public int getNbRow() { 00074 return nbRow; 00075 } 00076 }
 1.5.1
