org/objectweb/proactive/calcium/skeletons/For.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.calcium.skeletons;
00032
00033 import java.util.Vector;
00034
00035 import org.objectweb.proactive.calcium.Task;
00036 import org.objectweb.proactive.calcium.interfaces.Instruction;
00037 import org.objectweb.proactive.calcium.interfaces.Skeleton;
00038
00039 public class For<T> implements Instruction<T>, Skeleton<T> {
00040
00041         Skeleton<T> child;
00042         int times;
00043
00044         public For(int times, Skeleton<T> child){
00045                 this.child=child;
00046                 this.times=times;
00047         }
00048
00049         public Vector<Instruction<T>> getInstructionStack() {
00050                 Vector<Instruction<T>> v = new Vector<Instruction<T>>();
00051                 v.add(this);
00052                 return v;
00053         }
00054
00055         public Task<T> compute(Task<T> task) throws Exception {
00056
00057                 if(times > 0){
00058                         //Get Child stack
00059                         Vector<Instruction<T>> childStack=child.getInstructionStack();
00060
00061                         //Add the For with one less time to execute
00062                         childStack.add(0,new For<T>(times-1,child));
00063
00064                         Vector<Instruction<T>> taskStack = task.getStack();
00065                         taskStack.addAll(childStack);
00066                         task.setStack(taskStack);
00067                 }
00068                 return task;
00069         }
00070 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
