org/objectweb/proactive/ext/security/crypto/FixedSecureRandom.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security.crypto;
00032
00033 import java.security.*;
00034
00035
00036 class FixedSecureRandom extends SecureRandom {
00037     byte[] seed = {
00038             (byte) 0xaa, (byte) 0xfd, (byte) 0x12, (byte) 0xf6, (byte) 0x59,
00039             (byte) 0xca, (byte) 0xe6, (byte) 0x34, (byte) 0x89, (byte) 0xb4,
00040             (byte) 0x79, (byte) 0xe5, (byte) 0x07, (byte) 0x6d, (byte) 0xde,
00041             (byte) 0xc2, (byte) 0xf0, (byte) 0x6c, (byte) 0xb5, (byte) 0x8f
00042         };
00043
00044     public void nextBytes(byte[] bytes) {
00045         int offset = 0;
00046
00047         while ((offset + seed.length) < bytes.length) {
00048             System.arraycopy(seed, 0, bytes, offset, seed.length);
00049             offset += seed.length;
00050         }
00051
00052         System.arraycopy(seed, 0, bytes, offset, bytes.length - offset);
00053     }
00054 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
